Soldering mini machine - Opinions needed
Posted by Nuno Andresen on Thursday, July 8, 2004 3:21 PM
Can anyone recomend this soldering machine?
More info here:
http://www.ares-server.com/Ares/Ares.asp?MerchantID=RET01229&Action=Catalog&Type=Product&ID=80462A
My primary goal is to weld sheet brass, but working with Fe-C alloys is on my sight too for other purposes.
I would like to buy this one, but I would like to hear opinions from you first and to know other alternatives you may know, you may like, you may have in your modeling room.
Thank you!
    May 2003
Posted by qmiester on Saturday, July 10, 2004 7:50 PM
I have a friend that scratch builds HO scale brass equipment and engines and has a resistance soldering tool pretty much like the one you're looking at. I've used it a time or two when helping him on his model rail road. I would like to have one but can't justify it to myself or my wife - just don't do enough soldering. The only problem I see is you are probably going to have to shell out another 147 bucks to get the heavy duty soldering plyers to solder brass sheet together.
Quincy
Posted by Nuno Andresen on Saturday, July 10, 2004 7:54 PM
That is a fine comment on an issue I hadn't thought about, qmiester. Thank you!
