M3 masking tape, M3 Blue painters tape, or silly putty, whats better?
Posted by Anonymous on Tuesday, August 24, 2004 10:46 PM
please tell me which style of masking do you like best.
Posted by darson on Wednesday, August 25, 2004 12:37 AM
Hey Charles you're on fire with your posting today buddy. Big Smile [:D]
My personal preference is Tamiya masking tape, I use both the 6mm and 18mm tape and have found them to be viceless.
I also Silly putty or Blu tack when masking in certain situations (protecting the insides of canopies for instance).
Cheers
Darren
Posted by Anonymous on Wednesday, August 25, 2004 5:48 PM
in most Fine Scale mags ive seen blue painters tape used although I have herd good things about all of them.
Posted by dubix88 on Thursday, August 26, 2004 5:50 AM
HEY,
I use blue painters tape sometimes and it works great.
Randy
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
    January 2004
Posted by MusicCity on Thursday, August 26, 2004 7:53 AM
It varies on what I'm trying to do. My preference is to use tape (specifically Tamiya masking tape or 3M Blue) because sometimes it will be several days before the masking comes off. Other times, for a quick-and-dirty mask or in places that tape just plain won't work, Silly Putty, Post-It paper, dampened tissue, whatever is necessary.
It also varies with what you are using to paint with. Spray cans have a lot more pressure than most people use with an airbrush. Paint brushes put down a lot more volume of paint than most people do with an airbrush. For that reason, some things that work great with airbrushes don't work so well when using rattle cans or a hand brush.
Posted by Anonymous on Thursday, August 26, 2004 2:03 PM
thanks for your imput guys. question, where can i get some tamiya masking tape my LHS doesnt carry it.
Posted by Anonymous on Friday, August 27, 2004 12:28 AM
Got a Home Depot close by? Lowe's? Both carry it in the painting section.
    July 2003
Posted by Model Grandpa on Friday, August 27, 2004 1:22 AM
For Tamiya tape your LHS could probably order it for you. Other choice would be one of the online hobby shops that advertise on this site.
Regards, Dan Building Scale Models At The Speed Of Dark
Posted by Anonymous on Friday, August 27, 2004 2:38 AM
My 2 cents [2c]......all will have its place and use in most projects you'll find yourself wrapped up in......& you might wanna add "Blue Tac" to the list........
Posted by ABARNE on Monday, September 13, 2004 12:52 AM
My personal favorite is Tamiya's yellow tape. The stuff is very thin which minimizes thick paint edges. It cuts beautifully without leaving and fibers or fuzz to mar a sharp line. It is very strong which is useful if cutting a long, thin strip. It is fairly flexible to mold to surfaces with compound curves. It is tacky enough to stick well without being so tacky as to pull off paint.
3M Blue tape is fairly good and quite inexpensive compared to Tamiya tape. It is a touch thicker than Tamiya tape, and not quite as strong or flexible as Tamiya tape, although it has the good cutting and low tack properties of Tamiya tape.
Depending on the masking situation, if I need the super fine edge or strength of Tamiy tape. I'll use that otherwise, I'll use the cheaper 3M tape.
    March 2004
Posted by DanCooper on Monday, September 13, 2004 2:14 AM
It depends, for "hard" demarkation I use Tamiya masking-tape, but when I'm doing camo that has a "soft demarkation line silly-putty or even toothpaste have been used by me.
On the bench : Revell's 1/125 RV Calypso
    July 2004
Posted by tho9900 on Thursday, September 16, 2004 8:42 PM
usually Tamiya tape, Pactra also makes a tape the is similar (if not the same) as the Tamiya... if your LHS doesn't have the tamiya in the modelling section go to the R/C section and see if they have it... that's where I found the Pactra and it was a little cheaper too... same low-tack, smae properties as far as cutting and shaping...
I use liquid mask for very small areas and some canopies.. especially the japanese variety with their 1000 little windows per canopy piece, I put it on with a 2/0 brush or smaller for that...
for large areas I use 2" masking tape if it's gonna be a fairly quick spray... (it sticks very well if left too long... TOO well) I just burnish down around the edges I will be painting around and leave the rest either lightly stuck to or just free over the piece I don't want paint on...
    July 2004
Posted by tho9900 on Thursday, September 16, 2004 8:43 PM
oh yeah I use painters tape sometimes too.... low tack but kind of a fuzzy edge to it...
