Further to one of the previous posts here. In regards to breaking small bits.
When I drill with my smallest drills I use a cake of beeswax to lubricate the bit prior to drilling (I bought mine after reading about beeswax in the tip section of FSM and one of the How - To Books from Kalmbach years ago). Just a little twist into the cake of beeswax and then drill away on the kit.
It acts as a lubricant without any smearing on the plastic like an oil base lubricant and it makes it pretty easy to clean the little bits and the kit itself up when I am done.
The other thing I find helps to avoid snapping is a good handle and a well braced and secure item to be drilled.
Also if your drilling straight through holes it works for me to have something soft for it to jab into on the other side (other than your hand)
. As strange as it may sound Silly Putty works great for this. Hope this helps.
Cheers;
Gregory
