I have found my Dremel works best on styrene WAY under the minimum rpm of a cordless tool.
Just my two pennies, but you might be better off (if plastic is the reason for the purchase) to spend a little extra and get a variable speed control to go with the Dremel, because there will be times when only a couple hundred rpm are really needed!
Gip Winecoff
