Improvised Ring Cutter
Posted by Anonymous on Monday, March 21, 2005 12:44 AM
Thought I would share this. It worked near perfectly.
I made a base for a Dremel cutting base to make some rings. I measured out from the bit to the measurement I needed and drilled a tiny hole for a thumb tack as a pivot. Cut the outside diameter first and then the inside. The rings look like they were laser cut.
    February 2004
Posted by tlivancso on Monday, March 21, 2005 1:17 AM
Hatewall,
That looks great, cool job. Do you have working plans for the base that you could pass along.
Cheers
Thom Smile [:)]
IPMS Member #42958 /  AMPS Member #2091
IPMS Central Connecticut (President)
IPMS Northeast Military Modelers Association (Web Master)
Like Alice "I try to believe in three impossible things before breakfast"
Posted by Anonymous on Monday, March 21, 2005 2:24 AM
There really isn't much to it. As you can see in the picture, it is a piece of white styrene sheet. I cut 8 blocks of thick stock and glued them around the outside of the cutting base. The base just sits down in it and the bit is adjusted to cut below into the working material. It took all of 5 mintes to make.
Posted by Anonymous on Tuesday, March 22, 2005 4:17 PM
Hatewall,
How big are those rings... nothing to give a size impression. What do you use it for?
