What is a Pin Vise?? (dumb question number 13)
Posted by Anonymous on Friday, April 1, 2005 7:31 PM
Hello all
I have heard several mentions in both these forums, and other articles of Pin Vises. When I hear the word 'vise' I tend to think of a clamp of some sort. The addition of 'pin' suggests that it is small, or holds small things....
In usage however, it is generally referenced with making holes....
So my dumb question today... What is a Pin Vise?
If it really is used for making small holes, who makes them and who makes the best one?
Thank you for you help.
Yolev
    August 2004
Posted by jdavidb on Friday, April 1, 2005 8:31 PM
Pin vises hold small drill bits. Sometimes people use them as handles for files or screwdriver shafts or tap and die tools. They hold wire or solder for certain situations. They're like a handle, but they're also used as a reducer chuck for using tiny bits in large drills.
Zona makes a nice variety of pin vises. They have straight shafts, ball handles, swivel heads, etc. They also make a spring-loaded corkscrew hand drill that you just bounce up & down to drill a hole with.
    May 2003
Posted by qmiester on Saturday, April 2, 2005 11:14 PM
First off, the only dumb question is the one you don't ask (learned that a long time ago)
As has been noted, the pin vise has a chuck that will hold a small shaft (drill bit) - the majority have a chuck on each end. On one end the chuck will go from zero clearance up to about 3/64" and the other end opens from 1/16" to about 1/8". They're usually used for drilling very small holes or by placing a needle in them, for scribing.
Quincy
    September 2004
Posted by Borg R3-MC0 on Tuesday, April 5, 2005 9:39 AM
I use my exacto-type knive as a pin-vise. I haven't had a situation where it didn't work.
    January 2003
Posted by yardbird78 on Thursday, April 14, 2005 2:09 PM
It is a handle for holding very small drill bits. Think of it as a pencil with a drill chuck instead of a lead point. I have 3 of them in various sizes and I use the smallest one a lot. I have a set of drill bits that go from #61 to #80. The #80 is .013 inches in diameter. That is smaller than a straight pin, but a little larger than a human hair. These small drill bits are fairly fragile, so using an electric drill would probably break them. Several different types and sizes are available through Micro Mark tools. Go to: www.micromark.com and search for item #81497 for one example.
Darwin, O.F. Alien [alien]
The B-52 and me, we have grown old, gray and overweight together.
Posted by Anonymous on Saturday, April 23, 2005 6:05 PM
After a suggestion by a fellow modeller at a contest, I went to the local welding supply company and got a tip drill. This is basically a specialized pin vise that is used for cleaning the tips of welding torches. I got mine for $12 and it has 12 bits, from about 1/16 inch to really freakin small. Not bad for the price.
