toothpick, sanding sticks, tamiya extra thin
I guess I'm the only one who values tweezers in the top 3!
#1: Princess Auto set of tweezers
#2: Sticky Tack (or as some say BluTak)-invaluable to stick parts to mayo lids to them airbrush!
#3: a fine paint brush....at least something that is capable of painting cockpit details
On the bench:
Too much
In the hangar:
Again....too much
My most essential tool is a really good light for the bench. I have one of those ring light magnifiers. The jointed arm and the jointed light itself have knobs at the joints to allow movement to any position, then lock it there. In my opinion you cannot do really good model work unless you can see well.
An X-acto knife, sandpaper, and superglue. Although the latter of the two are technically a supply I can't live without them. I know that you asked about what three things you need, but consider at least ONE more item - a good cutting mat will save you a lot of damaged table tops, and dull, broken blades. A light with an adjustable headband is always helpful as Don said about having a good light source. You can't build what you can't see. If you're going to use superglue - ACETONE. It's your friend. I can't think of any other more useful items other than these since they're what I've spent thousands of hours building countless models with!
~ Cobra Chris
Maybe a picture of a squirrel playing a harmonica will make you feel better?
My not so short list.
On the bench: Academy 1/72 B-17G 'Blue Hen Chick'; 1/48 Tamiya Mustang III; Kitty Hawk 1/32 P-39.
Completed: 1/48 Tamiya P-51D Mustang - 'Show Bird', 1/32 Dragon P-51D Flying Tigers 'What if'; 1/32 Tamiya P-51D Big Beautiful Doll
Group build:1/48 Tamiya Mustang III; 1/48 Tamiya P-51D Show Bird
CNicoll Post it notes. Really handy for keeping photo-etch parts I'm cutting from not flying off, also good for masking.
Love it for masking over delicate surfaces, such as decals, even after clear coating.
