Glue drying
    May 2005
Glue drying
Posted by ozmod on Sunday, May 29, 2005 4:12 AM
Dear All,
Can anyone please help me with a solution to preventing zap a gap glue from drying rock sold after it has been opened ?
Thank-you
Question [?]ozmod
Posted by Anonymous on Monday, May 30, 2005 2:26 AM
hey mate, welcome to the forums....
to answer ur question, im not sure if this is the best way, but recently i have been using the cap of syringe needles (which make great liiquid glue appliers....ithink they cld even work with ca, but im guessing ud have to clean it out often) over the applicator... seems to work ok so far, the only prob is that they now stand so high, i knock them over alot more hehehe.... anyhoo, i used to use a toothpic, but that wasnt so great...i had the tpick get stuck in the applicator, the tpick broke when i tried to pull it out, that was the end of that bottle heheheh....
another thing which may help you, i have started not applying ca from the bottle, instead putting some in a film container lid and using a sweing needle with a cut off head in a pin vice to apply the glue..... its much neater....
anyways, hope this helps!!
Posted by Anonymous on Monday, May 30, 2005 3:31 AM
Keeping CA in the fridge will extend shelf life. Always make sure the nozzle is patent before storing. Other than thatSign - Ditto [#ditto]with evertything Tominator has said.
    May 2005
Posted by ozmod on Monday, May 30, 2005 3:58 AM
QUOTE: Originally posted by ozmod
Dear All,
Thank-you
Question [?]ozmod
    May 2005
Posted by ozmod on Thursday, June 2, 2005 5:58 AM
Thanks tominator and Simon U I will give your suggestions a go.
ozmodBig Smile [:D]
