X-Acto Blades - Which Ones?
Posted by Anonymous on Sunday, May 29, 2005 9:16 PM
I have recently accuired an X-Acto knife, and i was wondering, what kind of blade do i need. the one it has in it is an 11mm.
what exactly does that mean. is it the length of the blade or what? what do you guys recommend.
i only use it for cleaning up parts after cutting them off the spruce.
    January 2005
Posted by jinithith2 on Sunday, May 29, 2005 9:46 PM
I usually use the number 11 blade and I think they are longer than 11mm but it can take it.
also, a standard width knife will take any blades of the same width
    January 2005
Posted by jcheung5150 on Sunday, May 29, 2005 10:40 PM
I also use the 11, good for trimming and clean up work as you stated. I also use new blades to bore holes in gun barrels.
Jimmy Photobucket
Posted by rjkplasticmod on Monday, May 30, 2005 9:58 AM
The #11 blade is the most useful, but I keep a second one with a #10 blade as well.
Regards, Rick
Posted by Anonymous on Monday, May 30, 2005 4:58 PM
new and sharp #11's
and i also use #10 rounded, #16 & #12's
......you can never have too many shapes that are sharp and cut
    May 2003
Posted by qmiester on Monday, May 30, 2005 5:29 PM
I believe the numbering system for Xacto blades is taken from the numbering system used by the medical community for scapel blades and it refers someway to the shape of the blade (the blade on a #11 scapel blade is shaped just like the Xacto #11 blade, but the shank is somewhat longer plus the Xacto blade is somewhat thicker and stiffer)
I keep and use Xacto #11s, #10s (rounded tips) and #16s (sharp point but blade is about 1/8" wide). I also use scapel blades #11 and #15 (rounded tip like a #10 but only about 3/32 wide).
Quincy
Posted by Anonymous on Monday, July 25, 2005 12:51 PM
That's a #11 blade, not 11 mm. A VERY useful one. I buy them in boxes of 100, so I'm always using a sharp blade, and I'm not tempted to "keep slogging on" with a less-than-sharp one.
Other than that, I use a lot of #2, which go in the heavier-style Xacto handle, and are really useful for cutting thicker styrene. #11 and #2 will NOT fit in the same handle. You need 2 different knives.
Posted by seaphoto on Monday, July 25, 2005 4:01 PM
I too use the number 11 most - for cutting, scraping, applying small amounts of putty, all sorts of things. The can also be modified for other uses using a grinding wheel - the usual warnings apply here, safety glasses and so forth. I have even mounted a dremel grinding disc in my lathe, held the blade with the tool holder, and made very small custom scribers out of them. Very versatile.
I like the chisel blade as well, which needs the larger handle - I think it is a number 18. Works great for removing unwanted surface details, and by reversing and scraping lets you produce a nice 90 degree inside joint.
Single edge razor blades have their place too - probably my most used model tool.
Kurt
Kurt Greiner
Interested in large scale, radio control warships? http://www.warshipmodelsunderway.com
Posted by Torio on Monday, July 25, 2005 6:11 PM
I use almost only the n°23 blade ( round on both edges) with a n°2 handle as I don't like the n°1 handle grip ( too thin , it gives me cramps in hand )
Thank you all for coming José
Posted by Anonymous on Sunday, July 31, 2005 10:19 PM
I never found any use for anything other than the good old No. 11. That, and I always kept an entire box of single-edged razor blades around.
Brian B.
    July 2013
Posted by DURR on Saturday, August 6, 2005 12:42 PM
#11 count me in too
PS i have heard some singers on the radio that sound like they gargle with old rusty onesBig Smile [:D]
Posted by Anonymous on Friday, August 12, 2005 11:47 PM
I used to buy # 11 blades, now I just resharpen the old ones. When I bought a couple of Norton waterstones for sharpening woodworking chisels I thought I would try them on an exacto blade. I used the #4000 grit and #8000 grit to put a perfect edge on an old #11, drew the blade a couple of times across a razor strop, and it was so sharp it was scary.
I know you can buy the new blades for almost nothing, but sharpening them yourself actually gives you a better edge than you can get on the new ones. It's nice to shave a tiny sliver of plastic off without the blade digging in and gouging. Just make sure your health insurance is paid up 'cause you'll need it to pay for the stitches.
Just my My 2 cents [2c]
    February 2005
Posted by RadMax8 on Saturday, August 13, 2005 2:16 PM
You know what, I've got a nice knife sharpening kit that says it'll do xacto blades. Problem is i always seem to break the tip off mine. Anyone have a list of all xacto's blades and what they are good for???
    May 2005
Posted by Bgrigg on Saturday, August 13, 2005 6:24 PM
Everything you wanted to know about X-acto blades!
http://www.x-actoblades.com/xacto/gridpg.htm
So long folks!
    July 2004
Posted by matthew9 on Saturday, August 13, 2005 7:40 PM
I use a #10 and # 11blades. They handle most of the work for me.
Matt
    September 2003
Posted by stindle on Thursday, August 18, 2005 9:59 AM
I tend to use #10, #11 and #15 for most of mine those 3 tend to cover it all.
    January 2004
Posted by Ali1kj on Monday, August 22, 2005 10:03 AM
Easy I DON'T USE THEM
Way to brittle andkeep a poor edge
Buy a SwanMorton handel and good type of surgical blades....cheeper and better
But use 10 10a and 11 blades
Alasdair
Posted by Jim Barton on Monday, August 22, 2005 4:23 PM
Because I got tired of switching the blades every time I wanted to do something different, I've got no fewer than four knives, three with #11 blades, but each knife has a specific purpose. First, I have one that I use for what I call "general cutting." This is removing parts from sprue, scraping off excess plastic, cutting sheet styrene, stuff like that. If I want the extra sharpness of a new blade, I'll go to the knife that has the brand new #11 blade. (When this starts wearing out, I'll switch it to the "general cutting" knife and the old blade from that knife gets discarded.) Finally, a #11 blade that was dulled by scraping it on the cement is in the third knife; this knife is the putty knife. I dipped the handles of two of the knives in different colored paints for identification.
The fourth knife has a #10 blade in it. I don't use it real often but it's handy if I have to cut at a certain angle; it's especially good for cutting strip styrene. The handle on this knife was also dipped in paint. For heavier duty cutting, I have a handle with the #2 blade and even a couple of saws. Those are things I almost never use, but when I want them...
"Whaddya mean 'Who's flying the plane?!' Nobody's flying the plane!"
