Fine wire source
Fine wire source
Posted by Bones-coa on Saturday, June 11, 2005 8:30 PM
Don't know if you guys know of this, but I thought I'd share.
I went with my wife to the craft store tonight and found a great source for tin wire. If you go to the beading section, they have spools of wire from 18 to 34 gauge. They come in different colors but not all colors were avaliable in all sizes.
I haven't used it yet, but it should work great for wire looms, hoses etc!
Dana F On the bench: Tamiya DO335B-2 with LOTS of Aires stuff (On Hold) Trumpeter A-10 with LOTS and LOTS of aftermarket goodies! (On Hold) Tamiya 240ZG (In work)
    May 2004
Posted by mikeiw on Sunday, June 12, 2005 5:35 PM
I use common old house fuse wire, which you can get from any DIY shop for a few pennies. It's also useful if a fuse goes in the house Wink [;)]
    April 2005
Posted by wing_nut on Monday, June 13, 2005 4:42 PM
I picked a few spools of diifrent sized wire at Michael's ... a craft /art supply place. They came silver ad gold coloered. I found the if you roll short lengths beteween 2 sheets of very fine snad paper the have a bit of "tooth" to paint easier
Marc
Posted by Tinker on Wednesday, June 22, 2005 4:48 PM
For some reeaalllly fine wire ( as in human hair size ) get an electrical transformer designed for solid-state electronics boards. Break the plastic end-caps off and remove the insulation rap and viola-- a spool of superfine copper wire that will be excellent scale for wiring instrument panels, engine compartments, frame wire looms, etc. To make wire looms, lay lengths of this wire bunched together; put a spot of superglue on it to hold them together. Then decide where each branch circuit leaves the " loom" and bend one of the individual wires out there. When you have all branches done for that "loom", lightly cover the rest of the piece with super glue. Paint the piece with whatever color you need, then install ; making final adjustments.
" 'Polls' are surveys of uninformed people who think it's possible to get the answer wrong." ...Ann Coulter
Posted by Anonymous on Thursday, June 23, 2005 11:09 AM
Check out for old modules at your nearest service station or garage. Open them up and you can fined a copper coil inside cut tip and you have a good supply for years. Can be used as copper tone or to paint just pass it through a piece of sand paper to remove varnish and clean with a cleaner. To paint just add a drop of paint on a suface and run the wire through.
    June 2004
Posted by clfesmire on Friday, July 1, 2005 2:36 PM
Sources for fine wire:
Anything electronic, tear apart those old radios, VCR's, tape recorders. You'd be amazed at what is inside these things for the kitbasher/scratchbuilders.
A word of caution for those ready to dig into TV's and old computers: Cathode ray tubes contain mercury and a variety of bio-hazardous material.
Posted by Lufbery on Friday, July 1, 2005 3:11 PM
I got some very nice, fine, silver-colored wire from the pull-chain switch of a ceiling fan. Smile [:)] I'm using it now to rig control wires on my Martin MB-2.
Regards,
-Drew
Build what you like; like what you build.
