Size conversion tool
Posted by Anonymous on Monday, July 18, 2005 1:52 AM
Hello,
Was wondering if anyone could supply the conversion equation for determining what percentage a set of drawings/blueprints can be enlarged or reduced to a prefered scale. I did have this equation printed out at one time but misplaced it.
Thanks,
Hobbit 7
    November 2003
Posted by chopperfan on Monday, July 18, 2005 2:40 AM
Hey Hobbit! Sign - Welcome [#welcome] to the forums. I think you're gonna like it here.
Now for your question? Try this link.
http://www.wwi-models.org/misc/scalecon.html
Randie [C):-)]Agape Models Without them? The men on the ground would have to work a lot harder. You can help. Please keep 'em flying! http://www.airtanker.com/
Posted by Anonymous on Monday, July 18, 2005 4:37 AM
Thank you very much Chopperfan! Much appreciated!
    May 2003
Posted by jtilley on Monday, July 18, 2005 8:17 AM
Welcome to the Forum! One of the most useful tools a modeler can buy is a pocket calculator that works in feet, inches, and fractions of an inch. If it also converts between the English and metric systems, that's even better.
Such calculators used to be rare and expensive, but in the past few years they've become standard merchandise at hardware stores and "home centers," like Lowe's and Home Depot. If you have trouble finding one locally, try the Lowe's website ( www.lowes.com ).
Several levels of sophistication are available, but for model building the simplest probably will do. (You probably don't need to solve rafter slope problems, or estimate prices in terms of cubic yards of concrete.) A perfectly satisfactory calculator for model building can be had for less than $20.00.
To use the thing is simple. Say you're building a 1/72 scale model, and the plans you have in front of you are on 1/32 scale. From the chart in the post above, you know the conversion factor is .44444. So, using a ruler, take whatever measurement you like on the drawing. Enter it into the calculator - in feet and inches (assuming the drawing is in the English system). Divide that number by .44444. The calculator will give you the answer, to the nearest 1/64".
If the drawing was made with the English system and you prefer to go metric, go through those steps and hit the conversion key. The calculator will give you the answer in milimeters.
Believe me, this is a good way to spend twenty bucks.
    July 2003
Posted by zokissima on Monday, July 18, 2005 12:54 PM
Or, if you don't want to spend any money, or use conversion charts, you can just use a conversion calculator, many of which are absolutely FREE. There are a couple that were created in C, Java, and other languages by members of this forum.
If you'd like, post a request, or you can e-mail me at zzoranovic@yahoo.com and I'll send you what I have. I only have one or two, so if you post a request, you may find more than I can offer.
    August 2004
Posted by JLerch2 on Monday, July 25, 2005 6:30 PM
i hosted one for ya that i got a long time ago. has a lot of nice features, enjoy. just right click, save as, then when it downloads double click and tell it where to extract. you need both the .dll file and .exe file in the same place(folder) to use it.
http://bellsouthpwp.net/J/o/JoshLerch/Unit%20Converter.zip
