im looking for...
im looking for...
Posted by ipms40049 on Saturday, August 13, 2005 11:45 PM
.triangular shaped styrene strips, bigger than .125. Ive tried evergreen and Plastruct and they dont have them, anyone else have an idea where I might find these?
Pat Hensley Booneville, Ms "Thank you for being here and playing nice"...please do not drag sand outside the box ! CURRENT BUILD(s) Revell 1/72 U Boat VII C Tamiya Willys Jeep - for 2010 Nats Bronco's Staghound -for 2010 Nats Dragons M16 Multi gun carriage - for the 2020 Nats. LOL
Posted by seaphoto on Tuesday, August 16, 2005 1:18 PM
I have never seen bigger than that in styrene. Could you build your own out of styrene strip, with a brass tube in the center for strength? It would be stronger and more rigid than plastic.
Kurt
Kurt Greiner
Interested in large scale, radio control warships? http://www.warshipmodelsunderway.com
    April 2004
Posted by crockett on Tuesday, August 16, 2005 3:25 PM
Just use sheet styrene, laminate the sheets yourself with CA to whatever thickness you require, mark out with a drafting pencil and a straight edge and cut out the triangles. Wa la!
    February 2004
Posted by tlivancso on Wednesday, August 17, 2005 11:52 AM
Hello Pat,
Try Midwest Products Co. LTD.
They have a product called Super Styrene which has two different triangular shape one with 90 degree angles and one with 60 degree angles. The biggest size they carry is 0.197 inches / 5.0 millimeters.
http://www.midwestproducts.com/styrene.htm
hth
Cheers,
Thom Big Smile [:D]
IPMS Member #42958 /  AMPS Member #2091
IPMS Central Connecticut (President)
IPMS Northeast Military Modelers Association (Web Master)
Like Alice "I try to believe in three impossible things before breakfast"
