Carving foam
Carving foam
Posted by delov on Monday, September 12, 2005 7:38 PM
Does anyone know where to get high density carving foam?
Thanks,
B.
    May 2003
Posted by qmiester on Tuesday, September 13, 2005 7:44 PM
I don't know if you consider it carving foam, but I've had very good luck with insulating foam (at least on the little N scale model RR I piddle with). It comes in blue, green and pink and in thickness's of 1/2 to 3 inches. Biggest problem is you have to buy a 4 ft by 8 ft piece. And carving or sanding can be a real thrill with it's demonstration of the properties of static electricity. Anyway, check out your local lumber yard or home improvement store (ie Lowe's or Home Depot)
Quincy
