Cutting styrene
Cutting styrene
Posted by Anonymous on Thursday, October 13, 2005 5:27 AM
How do you safely cut styrene? i just use an xacto knife. but i have a problem with my AT-ST model. the kits head has his "eyes" shut. i wanted to safely cut the eyes open, but i'm afraid to make a mistake and my knife might go in the wrong direction. can i heat my knife on a candle for instance to soften the plastic while cutting it? any input will be appreciated..
    May 2003
Posted by styrene on Thursday, October 13, 2005 2:24 PM
I think there are a couple ways to accomplish your goal. Please understand these suggestions are VERY general, but should get you started:
1. Using the BACK of a #11 blade, carefully scribe the area you want to open. When deep enough, carefully use the blade portion to cut through the scribed area. Clean up with some sandpaper.
2. Using a small drill bit, drill a pilot hole in the center of each eye. Carefully enlarge the hole with your X-acto (or some needle files/rifflers) until you achieve the dimensions you desire. Use some sanpaper glued around a stick (or a needle file) to achieve the final shape and remove any rough edges.
3. Using a small drill bit, drill several holes around the periphery of the area you want to open. Then use a small saw blade (razor saw) to "connect the dots". Follow up with a small stick with sandpaper glued around it to achieve the final shape. (Again, you can use needle files or rifflers for this.)
For saw blades, I believe Micromark makes a set of blades that will fit your X-acto handle. They look like #11 blades except they have varying types of teeth--coarse to fine. I have a set, and wouldn't be without them. Micromark also sells needle files and rifflers; they are quite handy to have in your toolbox.
Hope this helps a little.
Gip Winecoff
    April 2005
Posted by wing_nut on Thursday, October 13, 2005 7:08 PM
I think styrene has hit it on the head with those suggesitons... but of course he would.... just look at this nameBig Smile [:D]
Marc
Posted by Anonymous on Thursday, October 13, 2005 9:02 PM
Thanks Gip, i'll have to find those tools first.would'nt want to make a mistake Big Smile [:D] off to the hobby shop!
    December 2003
Posted by thevinman on Thursday, October 13, 2005 9:23 PM
I'd go with styrene's option #1. That way, you won't have to scratch build the lids. (the AT-ST's eys are "shut" because the lids are down. They are actually hatches. If you go with the other options, you'll want to scratch build the lids from stock styrene. They seem to be a simple 2 dimentional shape...piece of cake.Cool [8D]
