Mr dissolved putty
    April 2006
Mr dissolved putty
Posted by Mandrake2006 on Friday, May 12, 2006 7:00 AM
Hello,
I filled some gaps with Mr Dissolved Putty and now, one day later, some spots are transparant and some white.
Is it supposed to be all transparent?
Greetings
Posted by Anonymous on Friday, May 12, 2006 8:30 PM
mandrake, i am a big fan of Gunze Sangyo products, mr. hobby etc. but i dont use the mr. dissolved putty, because they have a product called Mr.surfacer 500, i acts like dissolved putty to but much more easy to use. if you are going to use putty, i suggest the Tamiya "Light curing putty". dries in 2 mins under direct flourescent light. or you could use the tamiya regular putty.Wink [;)] but that dries longer.
    May 2006
Posted by Brews on Sunday, May 14, 2006 3:54 AM
I have a PM Ho 229 from which I'd lost the canopy, so I made a balsa plug the other day, and coated it with Mr Putty. That was the first time I'd used it. I suspect that if you had some clear spots, and some white spots, then you didn't stir it well enough. I didn't dry it under fluorescent light, just sunlight. It dried fairly slowly, though.
