Cutting out Panels
    March 2006
Cutting out Panels
Posted by Dubau on Monday, July 3, 2006 2:00 PM
I am looking to cut some panels out of a Corsair so you can see in the in side. How I think it should be done is by drilling out 4 holes in the panel and using a saw to cut it out.
OK now, is that the right way to do it and what kind of saw should I use ?
Thanks all
Bud
P.S. I know I have posted a lot on here and sometime the same thing over and over. It takes me a long time to remember things LOL
So please bear with me, Thanks
" You've experienced a set back, and without set backs and learning how to fix them you'll never make the leap from kit builder to modeler "
    January 2003
Posted by Triarius on Monday, July 3, 2006 2:37 PM
The right way to do it is what works best for you. Your proposed method is fine, and I'd use a jeweler's saw to cut out the panel. If you don't have a jeweler's saw, a jigsaw with the finest blade you can find may work. This is what I do.
It is generally better to cut well within (say 1/16 inch to 1/32 inch) within the ultimate opening, and then carve or file the final borders, as files and small knives are easier to control.
You can also scribe through, but I find that tedious, and the knife always slips at the worst possible time, leaving me a repair job, too.
If you have a motor tool with the right bits and speed control, you can grind it out with cutting burrs. But remember that power tools allow you to screw up a project far faster and more efficiently than you could ever manage by hand… Oops [oops]Sign - Oops [#oops]Angry [:(!] Banged Head [banghead] @#!#&*#$%!!! Boohoo [BH]
Big Smile [:D]
    March 2006
Posted by Yann Solo on Monday, July 3, 2006 2:40 PM
Do you want the panels to be still usable?  A rotary saw would be ok I guess.  You know the kind of saw that uses a drill bit and looks like a Dremel but can be slide horizontally.  That way you could follow any contour you like.  I don't know if I'm explaining this correctly??????  The only problem is the speed of the tool that can make the plastic to melt.
No matter where you go ....... there you are.
    March 2006
Posted by Dubau on Monday, July 3, 2006 3:05 PM
Thanks for getting back to me. What I want to be able to do is cut out a panel and have it left open like on a real jet if men were working on it. And I guess I will have to fix / puddy up the panel after I cut it out so it looks like to matches in size, right ?
Is this the jeweler's saw you are talking about ?
I found that on Micro-Mark.
And for the blades
http://www.ares-server.com/Ares/Ares.asp?MerchantID=RET01229&Action=Catalog&Type=Product&ID=22109
http://www.ares-server.com/Ares/Ares.asp?MerchantID=RET01229&Action=Catalog&Type=Product&ID=22108
http://www.ares-server.com/Ares/Ares.asp?MerchantID=RET01229&Action=Catalog&Type=Product&ID=22107
what one of these.
Thanks again all
Bud
    January 2003
Posted by Triarius on Monday, July 3, 2006 3:54 PM
That is the saw I mentioned. If you are buying the saw, I'd advise you to get an assortment of blades—one of each of the ones you asked about. You will probably break quite a few.
When they do break, you can often shorten up the saw and use the pieces. This also gives better control and less breakage.
What I would do is make a new panel first, before you cut out the old one. I'd use thin aluminum (not foil, maleable sheet stock). Metal toothpaste tubes and the foil on top of some wine bottles is excellent for this. Trying to save the old panel is possible, but not worth the trouble, IMHOAE.
    July 2003
Posted by MonsterZero on Monday, July 3, 2006 6:13 PM
The best tool for cutting out panel is a hot knife. As you can see in this picture of a commercial hot knife it's an ordinary soldering tool that comes with a screw on X-Acto blade for hot cutting.
This is the best, most precise tool for cutting out doors and panels. The edges will require some sanding and polishing but the panel that you had removed, once cleaned up, should be perfectly usable if you want to mount it in the open position.
    March 2006
Posted by Dubau on Monday, July 3, 2006 7:14 PM
Now that's sweet. I never even thought of that.
Thanks
Bud
    January 2003
Posted by Triarius on Monday, July 3, 2006 8:25 PM
I have to say that this has never worked well for me. The iron gets too hot, and the plastic just curls away from the blade. Using just the tip is better (like scribing, but faster) but I find the handle awkward and difficult to control.
    March 2006
Posted by Dubau on Monday, July 3, 2006 8:29 PM
See that's why I like these forums. You get both sides.
Thanks
Bud
Posted by AndrewGorman on Tuesday, July 4, 2006 1:35 AM
I've never had any success with a hot knife- the things just make a truly horrible mess with a ticj=k ridge of melted plastic on either side of a much too wide opening.   If I were opening up some panels that I wanted to open and re-use I'd thin the plastic down from the back and then scribe the outlines until the piece pops out.  That thinning could be done by hand with 60 grit sandpaper, or with the careful use of a Dremel tool with a speed control.  Model car guys open doors and trunks by using a tight piece of sewing thread as a saw- I've never done this myself, but it sounds interesting!  If you just want to buy stuff, there are some resin aftermarket sets that inculude hatches and the things behind them.
Andrew
    December 2004
Posted by Hippy-Ed on Saturday, July 29, 2006 2:52 PM
Thanks
Bud
That's great Bud! As long as ya don't get the business end of itLaugh [(-D]Laugh [(-D]
I believe Verlinden has a Corsair detail set which may be of interest to you. Opening panels are a bit tricky tho, I've experiemented with it not too long ago & did it by drilling 4 holes just inside the corners leaving a bit of room (as a precaution)then used the back of a #11 blade. It's tedious but, patience is a must. And, practice practice practice on some scrap styrene firstWink [;)]
If you lose your sense of humor, you've lost everything
    March 2006
Posted by Dubau on Saturday, July 29, 2006 3:22 PM
I am working on a F4U-1D Corsair now but the one I want to open the panels is for the F4U-1A. I have everthing extra I can think of to add to it from Verlindena and others.
Thanks for the tip. I do not know when I will start on it but good to know things.
Bud
    December 2004
Posted by Hippy-Ed on Saturday, July 29, 2006 4:27 PM
Have you started on the moto tug yet? I had thought of buying this kit for awhile & just curious as to how it fits & all.
    March 2006
Posted by Dubau on Saturday, July 29, 2006 6:20 PM
Here are some pics and info for the F4U-1D I am building.
http://www.finescale.com/FSM/CS/forums/652447/ShowPost.aspx
So for so good.
Let me know what you think.
Bud
    December 2004
Posted by Hippy-Ed on Saturday, July 29, 2006 11:49 PM
Looks good Bud, although, I didn't see anything on the moto tugBanged Head [banghead] I might just have to get one when I can afford itTongue [:P]
    March 2006
Posted by Dubau on Sunday, July 30, 2006 9:16 AM
It comes witht the Moto Tug I just don't know if I am going to use it or not yet
Bud
    December 2004
Posted by Hippy-Ed on Sunday, July 30, 2006 1:28 PM
LoL Bud! Why do  ya say that? I'm curious
    March 2006
Posted by Dubau on Sunday, July 30, 2006 6:56 PM
Why WHY WHY ! You asked.  I WILL TELL YOU WHY !  hehehehhehe
I am thinking of just putting the Corsair on something and just displaying it that way. I am looking for a stand that would look like a carryer deck.  But I don't know what I will do yet. Have to wait till I get to that part Big Smile [:D]
Bud
    December 2004
Posted by Hippy-Ed on Monday, July 31, 2006 2:28 AM
Ok, sounds good Bud. There is a company that makes carrier decks & hulls in 1/72 but, not sure about 1/48 tho. I just can't recall the name off hand.  So, does that mean the Moto Tug wont be used?
Here's the link
http://www.flattopsandmore.com/kits.htm
    March 2006
Posted by Dubau on Monday, July 31, 2006 7:41 AM
Cool Link. If you remember the one for 1/48 please let me know and no I will not be using the Tug.
Did you want it ?
Let me know I can ship it to you.
Bud
    March 2006
Posted by Dubau on Monday, July 31, 2006 7:43 AM
EDIT................ NM about the link, there is 1/48 in there, thanks for that Big Smile [:D]
But do let me know if you want the Tug.
Bud
    December 2004
Posted by Hippy-Ed on Monday, July 31, 2006 10:24 AM
Bud
Glad to have helped ya BudBig Smile [:D] and, PM inbound as I am interested in the Moto tug. I think they look coolTongue [:P]
