eureka!... I think?
    November 2003
eureka!... I think?
Posted by wildcard2 on Thursday, January 11, 2007 3:18 PM
So last night im looking at my revell 1/48 p-51d with its raised panel lines in all there glory, and i thought hey why not try to rescribe all the lines?(after sanding) hmmmm no tool for the job, took an old toothbrush cut the bristles off took a sewing pin bent it to 45 deg heated red hot stuck it in the end off the brush,secured it with super glue. when i used electrical tape as a straight edge along the panel line it worked beutifully and best its free! try this and tell me what you guys think
mark
    March 2006
Posted by Dubau on Thursday, January 18, 2007 7:46 AM
Cool Idea, thanks
Bud
" You've experienced a set back, and without set backs and learning how to fix them you'll never make the leap from kit builder to modeler "
    February 2007
Posted by T-rex on Wednesday, March 7, 2007 11:14 AM
I do use a oldtooth brush for some cleaning of parts and when the models it completent, but it to weak as a sand paper, but it does has some good use, I'm using it to remove glur shaving off my T-72, but the technique is good.
thanks anyway
Working on: Trumpeter SU-152 (1/35) Trumpeter E-10 (1/35) Heller Somua (1/35)
"The world is your enemy, prince of a thousand enemy. And when they'll find you, they will kill you... but they will have to catch you first ''
    June 2006
Posted by ModelMan8 on Wednesday, March 7, 2007 11:24 AM
I use an old tooth brush to clean out empty paint bottles.  Your idea sounds like it should work very well.  Thanks for the ideaThumbs Up [tup] I will give it a shot.
Chris
    January 2006
Posted by PatlaborUnit1 on Thursday, March 8, 2007 5:52 AM
Hi Mark
Back in the old days before scribing tools,and when Verlindens books were really pushing the subject that's exactly how we did it.
I never had that great of sucess with a bent pin but I have seen many kits that came out just fine using it.
   I like to run all my panel lines under running water with a toothbrush to get all the dust and stuff out, just in case
David
Build to please yourself, and don't worry about what others think! TI 4019 Jolly Roger Squadron, 501st Legion
