E-Z Mask, Polly Scale Flat, and Future
    November 2006
Posted by ww2modeler on Monday, May 14, 2007 7:52 PM
I have a lot of questions. Before this is over you'll be thinking will this guy ever shut up! But, here it goes.
1. What is E-Z mask and how do you use it. Is it good or bad.
2. Polly Scale Flat coat. Is this something you can use for sealing a model. If not, what is a good product for sealing the decals and then the model once done weathering.
3.Is future good for sealing decals and if so, do you apply it using a brush or do you spray it on.
Thanks in advance,
David
On the bench:
1/35 Tamiya M26 Pershing-0%
1/144 Minicraft P-38J Lightning-50%
Numerous 1/35 scale figures in various stages if completion.
Posted by Anonymous on Monday, May 14, 2007 10:19 PM
David,
Here is a good read that gzt directed me to in regards to future, I believe it has some info on decals there;
 http://www.swannysmodels.com/TheCompleteFuture.html
Hope this helps!
