Mr. Surfacer and nail polish remover?
Posted by espins1 on Wednesday, June 6, 2007 8:51 PM
I remember reading somewhere that you can use nail polish remover as a substitute for Mr. Thinner when doing seamwork with Mr. Surfacer (Q-tip and nail polish remover).
Is that true?  I don't want to test it on a model just in case the nail polish remover would harm the plastic.
Scott Espin - IPMS Reno High Rollers  Geeked My Reviews
    February 2006
Posted by bj342 on Wednesday, June 6, 2007 9:47 PM
I use 70% isopropyl rubbing alcohol and Q-tips to clean up Mr. Surfacer 500 and 1000.  It takes a moment or two for the alcohol to 'take effect' but once started it comes off quite easy, so easy, in fact, it will remove the primer if one is not careful.  I understand 90% isopropyl alcohol works even quicker.
Posted by espins1 on Wednesday, June 6, 2007 10:09 PM
Awesome, that's exactly the info I needed.  Thank you!  Smile [:)]
Posted by Anonymous on Tuesday, June 12, 2007 12:13 AM
You sure can, Cutex works really well even if the Mr Surfacer is dry. Just make sure the nail polish remover has acetone in it.
