What's with the glue's???
Posted by Anonymous on Monday, July 23, 2007 8:25 PM
Just getting back into modeling after about 25 yrs...   have a 10 yr old son that I'm going to try and teach about modeling, I was into it as a kid, but unfortunately got away from it...    Back in my day all you had was the orange and white tube of Testors glue or their bottle of liquid cement...      Now I see all these CA glues, accelerators, debonders, gap-fillers, glues for clear parts, plus the old ones...
Can someone give me an education on when to use one over the other, and what works best in what application???
Much thanks in advance...
    May 2005
Posted by Bgrigg on Monday, July 23, 2007 9:49 PM
Yes, glues have come a long way in all that time. There are three basic kinds (and I'm going to ignore the two part epoxies!): Liquid, Tube and CA (Cyanoacrylate AKA Krazy Glue).
Liquid: Best all round glue. I use Tamiya Extra Thin mostly, and have a bottle of their "regular" kind which I call Thick. I also have a bottle of Testors Liquid. All come with brushes for applicators. The Testors and the Extra Thin work by capillary action, and so are best for attaching longer pieces like airplane fuselages or ships. Place the pieces together, insert a razor blade to hold the gap open and touch the brush loaded with glue. Observe how the glue runs down the gap, them press together. It dries, or flashes off, very quickly and works by melting the pieces together. Properly applied and sanded, you won't be able to tell where the seam was. The capillary action also works with hands, and I don't think one of us hasn't glued together a fuselage, only to find a perfectly etched fingerprint melted into the most visible part!
Tube: Still a standby, but most of us don't use it anymore. I keep a tube of the orange Testors around as I find it good to attach small pieces that requires good initial "tack" or "grab". Mostly it stays in the drawer though. The Tamiya Regular I mentioned above is almost as good, and is easier to work with. I find that tube glue is much like melted mozzerella cheese on a pizza, stringy and tough to deal with!
CA: This glue isn't just Krazy Glue anymore! There are numerous brands, and three basic "weights": Thin, Medium and Thick. It can be used for gluing together disimilar items (brass to plastic, for exampel), and can also be used to fill gaps. In fact, the brand I buy is Zap-A-Gap brand. Be careful though, fully cured CA glue is very difficult to sand. This glue also comes with the typical CA characteristic of being able to glue your hand to whatever you touch, so be careful! Acetone based nail polish remover helps a little. CA glues dries by chemical reaction, and you can also buy accelerators which makes the bonding instant and permament!
Good luck with your son. I came back to the hobby the same way, and got hooked, while my son built a few and moved on to other things. Sigh [sigh]
So long folks!
    January 2007
Posted by Viper Has The Lead on Wednesday, July 25, 2007 1:26 PM
Hello BT,
            Welcome back to this crazy hobby. Smile [:)]
Plenty of hints tips and pictures on these links.  Best of Luck to you and your son, you wait till you see how small some of the Photo Etch parts are, let alone stick them to anything !!
Regards
Mick C.
"All modern aircraft have four dimensions: span, length, height and politics. TSR.2 simply got the first three right." Sir Sydney Camm
