In case anyone is searching for Pace booth info... I got the Peacemaker (largest)... few observations:
1. The 2 light bulbs are regular 75W incand... will heat up the top part of the booth REAL fast and REAL hot... a problem if you left your spray can on top of it like I did ;) I promptly changed them to 60W energy savers. looks like same amount of "light" , the extended bulb fits in the space, and your booth does not get hot!
2. Be careful moving it around.. the steel sheets can/could bend.... and have sharp edges.
3. It IS noisy, but moderate.. you COULD have a radio (loud) or TV on if you would like...my air compressor is actually a tad louder, but nothing bad at all.
4. Works well, the peacemaker has two fans and they really rip... the venting is high capacity air flow, and it DOES take care of the fumes (I tested this; I use enamels).
5. you need to practice and figure out how "deep" within the cabinet you musy have your model when you AB. Couple times I washed by AB with a blast of thinner at the end of a session, too close to the edge and got some blowback. But again, only when you are not deep enough in the cabinet and shooting high volume hi psi.
6. As mentioned before, this thing is HUGE... lots of space to leave your thinners, AB cleaning stuff, some model parts drying on the back, etc. Plenty of "elbow" room for larger pieces (ships, 1:32 A/c)
Have not used it enough to determine frequency of filter changes... but filters are furnace type, not the 70$ proprietary ones that Artrograph booths require.
Overall contruction is not too bad, but not excellent.. not very sturdy, you need a solid platform.. I would reinforce the main frame if I knew how to, to make the overall structure more solid.
In summary, a good investment; a tad pricey, but cheaper in the long run than Artrographs.. also the largest non-professional non-custom built spray booth you can find. If you have the space and moulah, high recommendation, with jury still out on filter change frequency, longevity and long term use.
