Scalpel Help
    August 2007
Scalpel Help
Posted by ben1227 on Saturday, September 1, 2007 10:03 AM
I just purchased the Squadron Tools Scalpel...I like it because its flat, so it wont roll, and the blades i'm sure are sharper than your average exact-o. But I  can't get the blades on! They look like they should snap on or something. Anyone who owns one please help Boohoo [BH]
.:On the Bench:. Tamiya 1/72 M6A1-K
    January 2003
Posted by Triarius on Saturday, September 1, 2007 10:21 AM
Getting in to self-surgery, are we? Laugh [(-D] Remember what these things are used for—a whole lot sharper than anything most people have ever encountered in daily life.
Notice that there is a groove on both sides of the prong that holds the blade. That prong goes into the slot in the blade. The blade slides into the groove, and snaps over the raised end of the prong. The slot in the blade has a narrow section toward the tip that engages the groove in the prong. The wide portion of the slot allows it to do this, and snaps over the raised portion at the back of the prong.
Holding the handle in your right hand, grasp the back of the blade, with the edge facing away from your hand, between the thumb and index finger of your left hand, just forward—towards the tip—of the slot in the blade.
Place the wide portion of the blade slot over the tip of the prong in the handle, and engage the narrow portion of the slot in the groove. At this point, you must hold the handle very tightly. If you don't you can push the handle out of your hand with the blade, which will slice the tendons of your fingers.
Push the blade toward the handle until the back (wide) part of the blade snaps over the raised portion at the back of the prong.
To remove a blade, notice that there is a small tab-like portion at the base of the blade that extends slightly away from the handle. Press this away from the handle to lift the back of the blade slot over the raised portion on the back of the prong, and push the blade (still using the tab you lifted) off the prong.
    August 2007
Posted by ben1227 on Saturday, September 1, 2007 10:35 AM
I've sliced a few fingers, nothing major. Yet Whistling [:-^]  Thanks for typing all that! I got it on, now I'll probably have trouble trying to get it off...
    January 2003
Posted by Triarius on Saturday, September 1, 2007 10:46 AM
Sad [:(]
I did warn you! See the last paragraph again and post any other questions you may have. I was a bit puzzled by them at first, too, since I knew medical persons had to do this with surgical gloves on, I figured there had to be a knack to it.
    August 2007
Posted by ben1227 on Saturday, September 1, 2007 11:00 AM
I got it off and on again! Without cutting myself Party [party] I was playing, umm i mean working with the scalpel and it is sharper than my old #11 exact-o blades...Each blade is individually wrapped in foil that says "Sterilized by Gamma radiation" -I thought this was a modeling scalpel, not a people scalpel Dunce [D)]
    January 2003
Posted by Triarius on Saturday, September 1, 2007 11:40 AM
A difference that makes no difference is not a difference. These things are made to do one thing: cut flesh. The only thing I know of that is sharper is a flint edge (that's right, a stone tool-Oog was no dummy) which has been shown to be several orders of magnitude smoother and finer than the best scalpels. Brittle, though.
    May 2005
Posted by Bgrigg on Saturday, September 1, 2007 11:55 AM
And difficult to make. There aren't many people that are capable of knapping a scalpel blade from flint.
So long folks!
    August 2007
Posted by ben1227 on Saturday, September 1, 2007 12:37 PM
Wow. So this thing is sharp...
MJH
    April 2005
Posted by MJH on Friday, September 21, 2007 8:05 PM
I found one of the main advantages of scalpel blades over the Exacto variety is that the tips are not nearly so easy to break.
If you're buying sterilized blades you're probably paying too much.  They're available non-sterilized at a significant saving.  I purchase mine from Hobby's in London though I daresay there are many other sources closer to home.  They have the 'real' Swann-Morton blades and they're cheaper than Micromark's generic versions.
Fitting the blades definitely is a little fiddly but the result is a firmly held blade that won't slip out no matter what you do.  I recommend a small pair of pliers for the job of replacing blades however - a slip could be nasty.
Michael
    January 2007
Posted by Viper Has The Lead on Saturday, September 22, 2007 7:26 AM
Hello Ben,
             Scapels are people cutting tools. Most excellent for modellers too, just remember they were designed to cut into flesh, and treat the blades accordingly. Many good Hobby suppliers have Swann Morten handles and blades, at reasonable prices, no need for sterilised ones.
There is also a new Swann Morten Blade Removal Unit, (Holds up to 70 blades) available,
Or a Single blade remover.
All the best,
Mick.
"All modern aircraft have four dimensions: span, length, height and politics. TSR.2 simply got the first three right." Sir Sydney Camm
