Riffler Files
  • From: 41 Degrees 52.4 minutes North; 72 Degrees 7.3 minutes West
Riffler Files
Posted by bbrowniii on Saturday, October 6, 2007 10:42 PM
Hey all,
 I have been eyeballing a set of riffler files in the most recent squadron catalogue.  Before I spend the $18.00 on them, I wanted to check and see if anyone has a set (or one similar).  Are the worth it?  Do you use them a lot?  Would you recommend them?
'All that is necessary for the triumph of evil is for good men to do nothing' - Edmund Burke (1770 ??)
Posted by Woody on Sunday, October 7, 2007 1:39 AM
They are nice to have when you need them.
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
    May 2003
Posted by qmiester on Sunday, October 7, 2007 7:49 AM
As Woody noted, they're really nice when you need them.  I don't use them on every model I build, but find that they will often get into areas that I can't get sandpaper or straight files into with out damaging the surrounding details.  Plus the shapes often let me maintain curves on the model better than straight files or sandpaper.
Having said that, would I recommend you run right out and by a set of riffler files.  That depends.  If you already own a set of jewelers files, then by all means get the rifflers.  However, if you don't have a set of jewelers files, I feel your money would be better spent getting them first, then a while down the road, getting the riffler files.
Quincy
    October 2005
Posted by usmc1371 on Sunday, October 7, 2007 8:31 AM
I had the riffler file set from Squadron.  They're ok, but a little hard to use at times because of their length.  I bought this set from MicroMark: http://www.ares-server.com/Ares/Ares.asp?MerchantID=RET01229&Action=Catalog&Type=Product&ID=82121
I've found them to be much easier to use and the handle can be used with my other files.
Just my opinion.
Jesse
Posted by Woody on Sunday, October 7, 2007 11:47 AM
I second the idea that a good set of jewelers or small swiss pattern files will get used more than the rifflers will. I use my riffs for rough shaping on most of my scratchbuilding projects.
Posted by bbrowniii on Sunday, October 7, 2007 9:08 PM
Guys,
Thanks for the insight.  I do have a nice set of jeweler's files already, so I think I might add the rifflers to my tool kit.
Once again, thanks for you input.
