what is it?
    October 2010
what is it?
Posted by nik007 on Monday, February 21, 2011 4:17 AM
hello am new at this and i want to ask something. what is:
-photoetched
-vinyl
-metal pins
-cast metal
-metal strengtheners
 thanks
    October 2010
Posted by nik007 on Monday, February 21, 2011 4:18 AM
the reason am asking its because i start reading the magazine and i see that a lot. also i forgot what is resin?
    September 2007
Posted by SuppressionFire on Monday, February 21, 2011 5:32 AM
nik007
-photoetched ~ Brass sheet with extremely fine details for scale model applications. Example would be  hand rails and crane structures for model ships.
-vinyl ~ Usually tank tracks or wheel washers to allow free movement. Difficult to join and always leaves a unsightly mark at seam.
-metal pins ~ Self explanatory.
-cast metal ~ White metal with a lead content, popular for 'gamer' figures or science fiction. Good detail.
-metal strengtheners ~ Self explanatory. Good to replace some delicate parts with metal. Example axles.
 thanks
Resin ~ Allows for greater detail in molded parts vrs. injected molded processes. Extra time required  to  manufacture and this is reflected in price. Fine dust from sanding created that should not be inhaled.
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    August 2006
Posted by HawkeyeHobbies on Monday, February 21, 2011 7:56 AM
Cast Metal is usually a zinc alloy mixed with tin. No lead as lead would pose a health risk with those handling the parts. These parts are made of the same material found to make metal toy cars...Matchbox and Hot Wheels.
Gerald "Hawkeye" Voigt
    August 2009
Posted by Sparrowhyperion on Monday, June 13, 2011 8:52 PM
PE or Photoetched parts are mainly pressed thin sheets of brass which have bee cut and/or painted to add extra detail to a kit.  An example would be instrument panels in aircraft, where you would have a lot of extra detail and clarity by simply gluing on a small pre painted panel on top of the plastic kit part for more realism.
Resin is a substance which can easily be molded into much higher detail parts than most manufacturer plastic parts and are usually added for more realistic parts for kits.  Usually these are after market kits and not normally found in the kits you buy themselves.  Examples of this could be super high detail exhaust cones or intakes for aircraft,  Some also come with additional PE metal parts for more detail.
Vinyl is an alternative molding material.  It is usually softer and more pliable.
In the Hangar: 1/48 Hobby Boss F/A-18D RAAF Hornet,
On the Tarmac:  F4U-1D RNZAF Corsair 1/48 Scale.
    August 2005
Posted by EdGrune on Tuesday, June 14, 2011 3:46 PM
Sparrowhyperion
Not entirely correct.   Photoetched material is thin metal which has been subjected to a chemical process which etches away some material and leaves remaining fine details.    The photoetching process is an offshoot of the printed circuit board manufacturing process.   The process is also referred to as chemical milling.  A photographic mask is applied to the substrate material which is then put in a caustic bath to etch/remove unwanted material.   Photoetch metal parts allow finer level of detail than can be obtained with normal injected plastic alone.
Sparrowhyperion
Resin parts are made from a two-part epoxy-like material, mixed, poured into a mold, and allowed to harden.    Resin material is generally more expensive than polystyrene plastic used in injected models.    But resin allows parts to be made more quickly and inexpensively when tooling costs and time are considered.  In addition to aftermarket detail sets noted above,   whole kits made from resin are available.   These are generally short-run models of unique subjects.  They are often called 'Garage Kits',   not because they are garage junk, rather because they are produced in someones garage or basement instead of a factory.
See also /forums/p/81787/798803.aspx#798803 for a complete listing
