scale size
hal
    March 2009
scale size
Posted by hal on Saturday, March 26, 2011 9:52 PM
hi guys , having trouble with certain scale sizes, for example a 1:18 represents what size in inches if possible, and is there a scale written that compares scale of a model to a size in measurements whether in inches or metric .cm, anyhelp would be apreciated, thanks
    August 2005
Posted by Phil_H on Saturday, March 26, 2011 10:38 PM
hal
Start with a known length and convert to the units you wish to use.
eg. one foot = twelve inches. one metre = 100cm
Divide by the scale.
12/18 = 0.6666 inches = one foot @ 1/18th scale
In metric,
100/18 = 5.555 cm = one metre @ 1/18th scale
hal
    March 2009
Posted by hal on Sunday, March 27, 2011 7:24 PM
hi phil, therefore if i use as an example my 1/32 scale corsair it is 323mm lenght and 390 width. which translates to roughly 11.81 inches x 15inches .
1:18 scale becomes much larger in size roughly 1.8 ft x 2.2 ft .  i used the dimensions from the us army plane F4U corsair, with a 33'4in fuselage and 41' wing span . thankshal
    April 2015
Posted by spadx111 on Monday, March 28, 2011 1:22 PM
good answer learned something yoday.
Ron
Posted by Don Stauffer on Tuesday, March 29, 2011 9:01 AM
1:18 is an odd scale in fractions of an inch per foot. It falls between 3/8 inch per foot (1:16 scale) and 1/2 inch per foot (1:24 scale).  So it is not ordinarily expressed as N inches per foot.  Scales that have a common fraction of an inch per foot are sometimes called "architectural scales,"  and are multiples of, or even fractions of 1/12 or 1/8 inches per foot.  1:18 is not an architectural scale.
    August 2006
Posted by HawkeyeHobbies on Tuesday, March 29, 2011 12:04 PM
To give you a comparison between 1:48 and 1:18
Gerald "Hawkeye" Voigt
