Knight667, here's a site you should check-out. I just found it on the Aircraft forum. It's an F-106 site with info and pix on all base's the 6 was flown from.
http://www.f-106deltadart/index.htm
You may find your markings here. If so, copy the pictures, edit out the rest of the pix, clean-up the graphic, and print your own decals.
" 'Polls' are surveys of uninformed people who think it's possible to get the answer wrong." ...Ann Coulter
