Welcome to the forum, Waterinjection. Here are 2 web addresses you can use to trackdown your info. I spent 22 years in active-duty US Air Force and for the first 4 years I was an Aircraft Weapons Mechanic. That meant I spent some time on the Arm / DeArm ends of the runways at a couple of air bases. I don't know the designations, but one type of RW arresting cable I saw laid accross the runway, side-to-side. Each end was attached to some lengths of chain that were made with some humongus ( technically speaking ) links that were laid parallel to the runway, out in the grass. When an A/C caught the cable with its tailhook, the lengths of chain provided some serious drag to slow and stop the plane. These cables were located about 3/4 of the way down the runway from both directions.
The second type of barrier I saw was two cables stretched accross the end of the runway between two steel posts. The posts were normally laying on the ground until needed, when the control tower operator could flip a switch and cause the posts to be raised to the vertical position. The cables were attached, one at the top and one at the bottom of each post. There were nylon ribbons tied vertically between the cables to make it easier for a pilot to see the barrier should he be using it. This barrier did not ALWAYS work. In 1969, at Bien Hoa AB, RVN one of my A-37 Dragonflies went through it without slowing down. It bounced over the bottom cable while the top cable slid along the top of the fuselage . The plane stopped when it came out of the ditch at the end of the runoff area and the landing gear folded making it belly accross the perimeter road. This happened after an aborted take-off. I helped the pilot climb out of the cockpit and we dee-deed down the fenceline. JP-4 was everywhere because the left wing buckled, but didn't catch fire -- thank goodness. He was only loaded with 6 GP bombs. If he'd had napes or ( God forbid, amen ) CBU-14's or CBU-19's, we would have had a different outcome. CBU's were very nasty. Their little bomblets armed 6 inches out of the tubes. Those things were disposable launch tubes loaded at the factory. Pilots NEVER brought these puppies back from a mission unless the package was hung-up and couldn't be shaken off of the wing. This happened every once in a while and EOD would meet a very nervous pilot at the end of the runway to visually varify each of the 6 tubes in each package was empty.
Oh wow, sorry for the diary. Here're the links: ( 1 ) www.searchmil.com This is a search engine for military websites. ( 2 ) This site --- www.au.af.mil/au/afhra/ can keep you busy for months running their links. You can find thousands of pictures through the links at this site.
" 'Polls' are surveys of uninformed people who think it's possible to get the answer wrong." ...Ann Coulter
