Ridiculous prices
    February 2016
Ridiculous prices
Posted by alumni72 on Monday, April 23, 2007 12:16 AM
I was tempted about a month ago on eBay to bid on a Frog 1/72 Martin Maryland kit - I won, and the kit was delivered safely and quickly to my door.  I guess I bid on the kit because it was a plane I knew next to nothing about - had hardly heard of it, in fact - and being a lesser-known plane it caught my interest.  Knowing nothing about it also meant that I'd have to do a good amount of research on it in order to do a decent job on the kit, when it came time.  So I searched for and found a Profile (#232) for the Martin Baltimore/Maryland, and bid on it.  Well, the bidding escalated more than I was used to seeing for a single Profile, but I had just gotten a nice fat refund check so I went with it.  I figured 7 or 8 dollars is usually more than enough to outbid anyone else for a single volume, but not this time.  So then I figured I'd go all-out and bid so far over the head of the highest bidder that there was no way I could lose, and I figured that in addition I most likely wouldn't pay nearly the amount I bid - so I bid $17 with a minute left to go.  Well, someone must have wanted that Profile very badly, because that $17 bid wasn't even high enough.  The high bid at the end was just shy of $18.
A week later I saw another copy of the same Profile, so I bid on that one.  Again the bidding escalated, and with a day left it was up to $11.  So this time I bid $18, thinking the last time was a fluke.  Nope.  The winning bid this time was $18.50.
Does anyone have any idea why these Baltimore/Maryland profiles go for so high a price?  By no means am I trying to collect the entire series, but I try to get a Profile for every plane I have an interest in, or in this case, that I have a kit of and don't know enough about from the reference materials I already have.  Are the later issues (#200 or above)  harder to come by?  Or is it just my dumb luck?
    July 2006
Posted by telsono on Monday, April 23, 2007 6:27 PM
It is probably that these profiles were prodcued in the 1960's and early '70's and are rapidly becoming collector copies. My collection was acquired primarily in my youth and a lucky find in a used bookstore of a small collection.
BTW that kit is very bareboned and the Azur kit which is of more recent vintage would probably be an easier build. I have the same kit as you from a Russian use of the old Frog mold and it seems to me to be a daunting task.
Just my 2 cents.
MIke T.
Beware the hobby that eats.  - Ben Franklin
Do not fear mistakes. You will know failure. Continue to reach out. - Ben Franklin
The U.S. Constitution  doesn't guarantee happiness, only the pursuit of it. You have to catch up with it yourself. - Ben Franklin
    October 2009
Posted by Ti4019 on Sunday, October 18, 2009 12:41 AM
just to resurrect an old thread and a continuing trend, Ebay is becoming a slaughterhouse for us that need a particular item that cannot be readily purchsed. I am currently bidding on a Navy Mk. II helmet and, as first bidder, I set my initial bid high. I have watched time and again these old helmets go in the 50-70 dollar range, this one is in really good shape so i expect it to go high.
It sat for four days with no action other that my initial bid, today the bid jumped 11 bids/ 50 dollars ,all by the same bidder, about 40 minutes apart, so it looks like a robot proxy bid.
I knew it would go high, but now the question is how high is the sky?
If you aren't having fun, you're doing it wrong! Build to please yourself and they will flame you every time!
Posted by DDonSS3 on Tuesday, October 20, 2009 8:51 AM
The Frog kit Maryland really isn't that terrible to assemble. Now if you want to add details, replace engines, rescribe panel lines, etc, then that's an entirely different story. I built one 15-20 years ago using the kit's (original) SAAF decals with RAF desert camo. I don't know how accurate those markings were, but it sure looked cool!
    September 2005
Posted by richs26 on Friday, October 23, 2009 1:10 PM
I agree that some of these book prices are ridiculous.  I was looking for some books on Amazon and saw the Warbird Tech B-17 book.  Some sellers wanted $98 for used copies and $182 for new books.  Sheesh.  I will keep checking it out from my local library for a month.
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
    November 2004
Posted by Gromit801 on Tuesday, October 27, 2009 1:59 PM
Don't forget that a lot of the Profiles came in bound volumes. Those can also be found on eBay and well worth the money.
They last longer than the individual Profiles.
