- Member since
January 2006
Milliput is an adhesive putty like polyester putty or plumbers epoxy putty. You will need toput on a layer of plastic or even silicone spray to be able to remove it. In the article online from Armorama it says to use cheesecloth to make a texture after it is all in place, but this could possibly leave "gaps" with no texture, I would texture mine first as i created them and then apply, IIRC that is what the article says in FSM #1.I have it at home, Ill check it when I get back. Mlliput dissolves in water adn you are always admonished to use wet fingers and tools to work with it. It makes a bit of a mess but it wipes up while wet. I have used a lot of epoxy putties over the years and my current favorite is Magicsculp. David
Build to please yourself, and don't worry about what others think!
TI 4019 Jolly Roger Squadron, 501st Legion
