P.E. Gotta be careful there !
    August 2008
Posted by tankerbuilder on Wednesday, May 6, 2015 6:12 PM
Photo - Etched - Brass .
Sounds good doesn't it . Look at all the stuff out there for cars , planes , tanks and ships . Some is really great , some good and some not to great but serviceable .
 What would you think then , at today's prices , when you get some and it's so thin and so fragile that it has to be replaced with scratch - built components of plastic , which was supposed to be avoided by the P.E. Purchase in the first place ?
       Here's a warning to all of you out there . Maybe you haven't had this happen yet , But invariably you will experience it . When you receive your sought after  P.E. do this and you'll avoid the problem .Take the P.E. Out of the envelope and place it in a container of warm water containing some Dawn Dish soap ! Stir a little and then using a full blush brush swirl it on the parts in the water for about a minute .Then rinse in very hot water .
 Let the parts air dry . Put in a clean Zip - Loc bag with the instructions , Purge out the air and seal till needed . I think this is what I experienced .The parts were etched , rinsed , dried and enveloped and shipped .BUT , I don't think they were rinsed well enough .I don't think they rinse them under running hot water .
     This causes contamination of the rinse water and a little of the etching chemical remains , to work on the parts while experiencing the ambient humidity in shipping and such . Remember the envelopes are usually NOT airtight ! So you get very frail patterns , but certainly not parts that you can bend , fold , solder or use , except as patterns for new scratch - built ones .
 Let this be a warning . With rising prices we need to protect everything we get that is made of White Metal and P.E. Brass or Steel . Go the extra step and clean it once more and store in Zip - Loc bags .
  Yes , I used the bag brand name because I have found they are the absolute best for keeping things dry and airtight ! I even mix paint in the little ones ! Don't laugh , They thus , serve a dual purpose and I don't have to keep cleaning out mixing bottles .       Model On - - - -Tanker - Builder
    December 2011
Posted by Chrisk-k on Wednesday, May 6, 2015 7:32 PM
I just seal PE parts with Future and store them.  That serves two purposes - protect PE parts and make acrylic paint adhere to them much better.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    August 2008
Posted by tankerbuilder on Thursday, May 7, 2015 9:29 AM
AH !
   That's good too . I just don't put any paint on them or Future because of soldering problems if the parts are coated with anything . I do a lot of work in 1/96 scale so many parts have to be soldered  .
    April 2020
Posted by mikelberry on Wednesday, April 22, 2020 9:09 PM
Tank Builder, I am new to the world of Fine Scale Modeling. I have a Minicraft 1:350 Titaninc that I've been sitting on since 2008. I already had some PE parts for it. Lately, due to Covid, I've been focusing on it a little more. I'm slowly building my workshop, getting ready to build this thing. As I collect more PE, the main question that keeps bothering me is: How do you paint these PE parts without sacrificing some of the intricate detail? for instance, I have PE benches and deck chairs that are so intricate, you can't see the full detail without a magnifying glass. There are holes between the woven slats that are smaller than pinpoint. How the heck does someone paint these PE parts without clogging all of this wonderful detail? I would deeply appreciate any guidance you might provide.
Thank you,
Mikel.
    April 2020
Posted by mikelberry on Wednesday, April 22, 2020 9:54 PM
Thank you,
Mikel.
    March 2015
Posted by JohnnyK on Thursday, April 23, 2020 11:49 AM
One more thing. I always wear eye protection when I am using PE parts. Those things are really small, sharp and tend to fly like a Bat Out Of Hell.
    September 2012
Posted by GMorrison on Thursday, April 23, 2020 12:10 PM
mikelberry
Thank you,
Mikel.
Do you have an airbrush? If so, put on a light coat of primer. Then, as long as you keep the coats light, it should paint just fine. I have trouble with fine screens, but careful painting should be fine.
Or use Tamiya primer in the spray can.
    April 2020
Posted by mikelberry on Thursday, April 23, 2020 12:27 PM
Tank builder, thanks for your reply. I hadn't thought about using an airbrush. I guess that's a new piece of equipment that I will need for my work bench. I'll have amassed a greater expense for the equipment required to build the model, than for the model itself. But, nice thing is, I'll be ready for the next one.
    January 2010
Posted by rob44 on Thursday, April 23, 2020 5:06 PM
When I get PE I clean it then brush on some vinegar on it and let it sit for a few minutes then rinse it off. I believe the weak acid in the vinegar etches it a bit and allows paint to adhere to it better.
