You could just use the thinner grades of aluminum foil, too. It's usually the cheaper grade than the thicker aluminum foil. I think there are a couple of builds in the Aircraft forum that illustrate using kitchen foil, with white glue as the adhesive. I remember a build of Monogram's B-29 kit, using kitchen foil.
Also, here is a thread at the ARC forum, demostrating using kitchen foil and Micro Scale foil adhesive:
http://www.arcair.com/tnt1/101-200/tnt137-BMF-Popojan/00.shtm
OK, and here is the B-29 build I was thinking of, it's also at ARC:
http://www.arcair.com/Gal5/4601-4700/gal4687-B-29-Shred/00.shtm
I will try this myself, some day, just haven't gotten around yet to queuing up an NMF subject in my modeling queue.
Hope those articles help!
Best regards,
Brad
