Stephenson's 1829 Rocket The first passenger steam locomotive http://en.wikipedia.org/wiki/Stephenson%27s_Rocket
I'm from the government and I'm here to help.
Pratt & Whitney R-1830 Twin Wasp
Cyrus McCormick's mechanical reaper invented in 1831
Furuno fmd 1832, a bit of a familiar piece of equipment
Rhodesian Air Force DH-100 Vampire #R1835
Alamo
Here are some models kits and models of the Alamo
Up! Verlinden kit #vpi1837
1838
12-pdr field howitzer model 1838
The SCOTTISH MAID was one of the fastest sailing ships of her time, with large sail area and sleek lines. The schooner was built 1839 by Alexander Hall & Sons, Aberdeen, Scotland. The SCOTTISH MAID was one of the first ships with the so-called Aberdeen bow. She sailed about 40 years until she ran aground in 1880 and was lost.
Sikorsky HG-34 G
Hughes XH-17 Flying Cane #50-1842 http://en.wikipedia.org/wiki/Hughes_XH-17
Grumman F4F Wildcat BuNo 1844
Republic RF-84F Thunderflash #51-1845
I wonder if a model of the XH-17 (1840) has ever been tried. A small fortune in rod styrene needed.
You've got that right, roony. When I found those photos, I did a side search for models of it but no luck.
It would seem to be a fairly do-able scratchbuild as many components were off the shelf from other aircraft.
The XH-17 was a heavy-lift rotorcraft that was designed to lift loads in excess of 15 metric tons. To speed construction, parts of the XH-17 were scavenged from other aircraft. The front wheels came from a B-25 Mitchell and the rear wheels from a C-54 Skymaster. The fuel tank was a bomb bay-mounted unit from a B-29 Superfortress. The cockpit was from a Waco CG-15 and the tail rotor from a Sikorsky H-19 was used for yaw control.
1846
What is up with the double posting, castelnuovo? I thought is was supposed to be one at a time. Are you in a hurry?
Patton and Staff Verlinden kit #vpi1848
California Gold Rush- 1849
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
- Plankton
LSM
subfixer What is up with the double posting, castelnuovo? I thought is was supposed to be one at a time. Are you in a hurry?
No hurry.
If you look at the times, there are quite a few hours between my posts, and if I do post two pix in a row it is only twice a day and not every day. So no rush.
I take a break in my studies/work but don't have time to go for a long run. So I put up a post. Few hours later I take a break in studies or work and post one more. It doesn't have to be one at a time, its not that I am posting a whole bunch of them in a short time period.
If you feel like posting more then one, sure, why not? Maybe not 5 or 10 in a row but 2? With few hours in between? Sure...
To go with your 49er post above:
Revell #H-1851, 1968 reissue (originally from 1959)
Greg
George Lewis:
Jules Henry Giffard's airship from 1852
