Aircraft Trivia Quiz
    June 2004
Posted by cardshark_14 on Friday, October 10, 2008 5:25 PM
Ok,
Tell me the story about this:
this:
and this:
Cheers,
Alex
Never trust anyone who refuses to drink domestic beer, laugh at the Three Stooges, or crank Back In Black.
    January 2007
Posted by trexx on Friday, October 10, 2008 5:50 PM
 cardshark_14 wrote:
Ok,
this:
and this:
Cheers,
Alex
Wild Flippen' Guess:
Large bore guns were fitted to a PBY and the muzzles sported condoms to protect the bores from ocean conditions...
    October 2007
Posted by Milairjunkie on Friday, October 10, 2008 5:58 PM
4 50cal's fitted in the bow window of a catalina, as devised by W.J. Lahodney of Patrol Bombing Squadron 52 (Black Cats).
this:
A Catalina named after a bad cartoon being worked on.
and this:
The Catalina Trojans, possibly your local team?
    June 2004
Posted by cardshark_14 on Friday, October 10, 2008 5:58 PM
Yeppers! From the book Black Cat Raiders of WWII, and more specifically from Aeroscale's Lucky13:
"In his quest for increased firepower, Lahodney made several flights in the Army's B-25 bombers and was impressed with their gunfire capabilities. These planes had 75 mm in the nose but also several fixed-quad .50 caliber machine guns which were was of particular interest to the Cat pilot.
He decided to experiment with the same .50 caliber installation in the nose of his PBY. It was a somewhat radical concept and, as might be expected, there were many raised eyebrows. The PBY after all was a patrol plane, not a fighter, and it was the opinion of some that the fifties would tear the nose of the airplane. The old cat was simply not built to take that kind of abuse, they said. Others thought the installation would have an adverse effect on the aircraft weight and balance.
Few were optimistic that it would work.
Lahodney was not to be deterred. Removing the bombsight (which had not proven very effective for the specialized work of the Black cats) and the small bow plate window, he bolted the guns, mounted two over two, to the keel of the big boat. The top set of the two was mounted forward of the lower set, so the muzzles of all four were aft of the angle of the angled bow plate.
An aluminum panel with four blast tubes extending forward for seven inches replaced the window, and was all that was visible of the lethal addition from an exterior view. An electric trigger on the pilot's yoke and a selector switch which permitted the pilot to fire the guns individually or together, completed the installation.
Bill lahodney was confident that the Cat would not only withstand the vibration of the fifties, but that twin thirties normally mounted just above that spot could be retained along with the gunner's position.
With a minimum volunteer crew, consisting of himself, a flight engineer, and a bow gunner, Lahodney took off from Palm Island seadrome to try out his idea. Dropping a floating smoke light in the water for a target, he executed a wing-over and put the Cat into a steep dive.
Eyeballing the burning smoke light he pressed the trigger and the fifties responded with a burst that churned the water and extinguished the smoke. That was the kind of firepower he was looking for. During the run he had also noted that the extra weight in the nose had no perceptible effect on the aircraft's performance.
The test was repeated with the same result and upon returning to base, a careful inspection revealed that the old Cat had shouldered her new burden without complaint. The experiment was a complete success, so much so that the quad fifties were installed in at least three planes in every succeeding squadron.
Other tests also bore out Lahodney's views. They demonstrated that a gunner could straddle the quad mount and operate the thirties with almost as much mobility as before. A burlap pad was placed on top of the hot .50 caliber barrels to prevent the gunner from being burned.
One problem with the installation was that because of its positioning it was difficult to keep saltwater from getting into the muzzels. Rubber plugs were made to fit in the blast tubes but they leaked badly. Then someone got the idea that the standard rubber devices used for the prevention of venereal disease would be just the thing to make the blast tubes watertight. And they were.
In preparing for the coming deployment, Lahodney flew over to Townsville on the Australian mainland on a supply run. He picked up two additional quad mounts from the army supply depot and an unusally large quantity of condoms to protect the gun muzzles. The swells were heavy that day and during the take-off run one bounced the Cat into the air prematurely. The starboard wing dropped about forty degree and full power on the starboard engine would not bring it level.
It hit the water and broke off and the rest of the airplane came down hard. As it began to sink, Lahodney again applied full throttle and ran the broken Cat up on the rocks of the Townsville breakwater. Incredibly, no one was hurt.
With a heavy on-shore wind, the condoms were scattered about and it looked like there were many thousands as they floated ashore. Lahodney recalls that since there were no women on Palm Island there were much humourus speculation concerning the intended use of all those contraceptives."
Now that would make an interesting diorama...Wink [;)]
On to you, Trexx!
Cheers,
Alex
    June 2004
Posted by cardshark_14 on Friday, October 10, 2008 6:03 PM
this:
and this:
Laugh [(-D] Ok, now that got a good belly laugh out of me!  Nice one...
Cheers,
Alex
    January 2007
Posted by trexx on Friday, October 10, 2008 6:35 PM
 cardshark_14 wrote:
Yeppers! From the book Black Cat ...On to you, Trexx!
Cheers,
Alex
Wowie! Cha-Ching!
*trexx does that victory jig thing*
I'm currently thinking of a question...
    October 2007
Posted by Milairjunkie on Monday, October 13, 2008 5:53 PM
Trexx - are you still doing that victory jig thing?
Did you get talent spotted for the jig & move to greener pastures?
Or are you planning the ultimate question?
    March 2007
Posted by bondoman on Monday, October 13, 2008 10:36 PM
 trexx wrote:
Cheers,
Alex
Wowie! Cha-Ching!
Good lord, I was afearin' that!
    March 2007
Posted by MattSix on Tuesday, October 14, 2008 11:42 AM
Smile,Wink, & Grin [swg]
 trexx wrote:
Cheers,
Alex
Wowie! Cha-Ching!
I think I hear the Jeopardy Theme Song playing in the background.... Smile,Wink, & Grin [swg]
    January 2007
Posted by trexx on Tuesday, October 14, 2008 4:23 PM
I apologize for a delay. I've been distracted with the fun of finishing up my two, F-106 Delta Darts...
I'll just put this out there without the usual "Google" proofing screening. So open the flippen' floodgates!
Question:
What fighter plane hadn't an engine?
    June 2004
Posted by cardshark_14 on Tuesday, October 14, 2008 5:29 PM
No google involved: Bv 40.  I've got the Czech Model kit fo this very odd glider fighter plane.
Cheers,
Alex
    January 2007
Posted by trexx on Tuesday, October 14, 2008 9:14 PM
Cheers,
Alex
Oh, man!
You maka me sick! You, Googeless S.O.B. Wink [;)] You're EVER SO CORRECT!
I'm wondering what scale the Czech model is?
It's your turn Cardshark!
    March 2007
Posted by MattSix on Tuesday, October 14, 2008 10:33 PM
I'm glad that thing never saw combat! Those pilots would have been SPAM in a can!
Can you imagine taking on a 100+ formation of B-17s or B-24s, plus their fighter escorts, in a GLIDER!!!!???? Confused [%-)]
    June 2004
Posted by cardshark_14 on Tuesday, October 14, 2008 11:14 PM
 trexx wrote:
Cheers,
Alex
Oh, man!
This is the kit I have...picked it up for 5 or 10 bucks at a show.  It's a nice, easy build.
http://modelingmadness.com/reviews/axis/luft/lesterbv40.htm
Question as soon as I come up with one...
Cheers,
Alex
    June 2004
Posted by cardshark_14 on Tuesday, October 14, 2008 11:17 PM
I'd be willing to bet that it would've been about as safe as attacking in a Komet...probably more so...It had a smaller cross-section, and a LOT of armor.  Decent weapons loadout too.
Question in 5.
Cheers,
Alex
    June 2004
Posted by cardshark_14 on Tuesday, October 14, 2008 11:35 PM
What task were the Me 323, the B-29, and the B-52 all used for?
Cheers,
Alex
    May 2008
Posted by Puma_Adder on Wednesday, October 15, 2008 12:52 AM
Low altitude missions?
Some people spend their whole lives wondering if they made a difference. Gundams don't have that problem.
    September 2008
Posted by WarHammer25 on Wednesday, October 15, 2008 6:48 AM
Just a wild guess: aerial refueling?
The only easy day was yesterday - U.S. Navy Seals
Posted by osher on Wednesday, October 15, 2008 6:56 AM
They carried parasitical aircraft? (parasite aircraft, which are air launched)
    September 2003
Posted by mojodoctor on Wednesday, October 15, 2008 8:37 AM
Target? Okay, terrible joke I know!
How about reconnaissance?
Matt Fly fast, fly low, turn left!
    January 2007
Posted by trexx on Wednesday, October 15, 2008 12:37 PM
A:
Break a siege. (?)
    June 2004
Posted by cardshark_14 on Wednesday, October 15, 2008 5:51 PM
Osher, you got it!
Each of the aircraft was the mothership used in testing another aircraft:
B-29: X-1 - Sparked the question, as yesterday, October 14, was the 61st anniversary of Chuck Yeager's flight that broke the sound barrier! Happy B-Day [bday]Make a Toast [#toast]
B-52: X-15
Me 323: Me 262
On to you, Osher!
Cheers,
Alex
    January 2007
Posted by trexx on Wednesday, October 15, 2008 6:09 PM
...Me 323: Me 262
SAY WHAT?!! Where'd they hang that puppy???
    June 2004
Posted by cardshark_14 on Wednesday, October 15, 2008 6:27 PM
...Me 323: Me 262
The Me 323 was unmanned.  I don't recall what they were testing...Anybody?  Help? I've forgotten where I read about this...
Cheers,
Alex
Posted by osher on Wednesday, October 15, 2008 6:29 PM
This British aircraft type was sold off by the RAF, as not needed, to a specialist company.  It's ironic that the RAF then had to lease them back several years later, to perform exactly the sort of role they was designed for!  What was the aircraft?
    January 2007
Posted by trexx on Wednesday, October 15, 2008 6:50 PM
 cardshark_14 wrote:
...Me 323: Me 262
Cheers,
Alex
Good GAWD! There's no FLIPPEN' WINGS ON IT... and upside down??? OMG!!!
    June 2004
Posted by cardshark_14 on Wednesday, October 15, 2008 6:52 PM
 trexx wrote:
 cardshark_14 wrote:
...Me 323: Me 262
Cheers,
Alex
Ah Censored [censored]!  I misspoke...the Me 262 was unmanned, not the Me 323...sorry...
Cheers,
Alex
    November 2003
Posted by tempestjohnny on Wednesday, October 15, 2008 7:16 PM
 MattSix wrote:
Hmmmm....is it Republic?
P-47 Thunderbolt - "The Jug"
F-84 Thunderjet - "Lead Sled"
F-84F Thunderstreak - "Thud's Mother"
F-105 Thunderchief - "Thud"
A-10 Thunderbolt II - "Warthog"
Sory guys had a brain fart and forgot to check on this.  Matt is correct from my question.  For the Thunderjet I was thinking of "Hog" and the Thunderstreak "Super Hog" but thats it.
    September 2003
Posted by mojodoctor on Wednesday, October 15, 2008 8:33 PM
Uh, I don't get it.
If the Me-262 was unmanned without wings, what use is it and how is it a parasite?
Was it dropped as a bomb?
    June 2004
Posted by cardshark_14 on Wednesday, October 15, 2008 8:41 PM
 mojodoctor wrote:
Uh, I don't get it.
 cardshark_14 wrote:
Osher, you got it!
B-52: X-15
Me 323: Me 262
On to you, Osher!
Cheers,
Alex
