Aircraft Trivia Quiz
    January 2009
Posted by F-8fanatic on Wednesday, April 29, 2009 5:22 PM
 mojodoctor wrote:
In 1981, I chucked a paper airplane off the top of Half Dome in Yosemite, and I flew my kite the same day. Does that count? :)
Astronauts flew paper airplanes in an experiment aboard the International Space Station that flies at a minimum altitude of 173 miles above the Earth's surface. Does that count? ;)
haha nope, I didnt even think of that...
I am talking about the highest altitude that a paper airplane was launched into the atmosphere, as in outside.
    September 2003
Posted by mojodoctor on Sunday, May 3, 2009 8:29 PM
I thought I had run across reading something the other day stating that a person flew a paper airplane while at the summit of Mt. Kilimanjaro, but I can't find it now.
I take it that my flight on top of Half Dome at 8,800+ ASL feet isn't high enough? ;)
Matt Fly fast, fly low, turn left!
    January 2009
Posted by F-8fanatic on Monday, May 4, 2009 12:53 PM
No sir, that isnt it.
wow, I didnt think this would stump everyone.....ok, time for a hint.  When I say "launched", I dont mean that the paper airplane was thrown from someone's hand.  It was launched by one of its real-life brothers.....
    January 2009
Posted by F-8fanatic on Wednesday, May 6, 2009 4:55 PM
ok, I guess we'll just give the answer on this one.
In 1966, an F-8D Crusader launched a paper airplane from the speedbrake well at 50,125 feet indicated.  They put the airplane into the air brake well, pumped the boards shut before startup, and then launched it at that altitude.  Squadron was VF-13....my dad was a jet engine mechanic/plane captain with that squadron on the Shangri La.  You can read about it a little bit on http://www.f8crusader.org/ under "records set by the Crusdader".
 Incidentally, this same squadron was once again on CV-38 Shangri-La the following year, in the Med, when they were having trouble with a Russian trawler.  Back in the cold war days, the Russians would use old trawlers as spy ships, intercepting radio communications and such.  They would shadow our carriers, and often times harass them.  A favorite tactic of the Russians was to get in the way when the carrier was trying to turn into the wind to launch aircraft.  This particular time, the trawler gave Shangri-La a bit of trouble.  VF-13 loaded 13 rolls of toilet paper into the speedbrake well once again.  From the same website I listed above:
 Cleanest Bomb Attack On Soviet Vessel - Med, about May 1967. 13 rolls toilet paper (unused) loaded into speed brake well (I liked that speed brake). Hard right off cat, gear up, opened boards over trawler maneuvering to force carrier to turn. No medal, but no hack either.
I also recall a time my dad told me about a long time ago, it was the same scenario, and they loaded bags of flour into the speedbrake well.  Pilot made low-level pass and dropped the flour right down the smokestack.
    March 2006
Posted by simpilot34 on Sunday, May 10, 2009 5:34 AM
Whistling [:-^]
Cheers, Lt. Cmdr. Richie "To be prepared for war, is one of the most effectual means of preserving the peace."-George Washington
    March 2006
Posted by simpilot34 on Saturday, May 16, 2009 7:48 AM
Ok, well we have seemed to hit a slump again. Have to keep kick starting this thing!!!!!
Here's the next one then:
Whaddat?
    October 2005
Posted by Brumbles on Saturday, May 16, 2009 8:16 AM
I dunno ... but I WANT one!
Could it be based on the A-20 Havoc?
    September 2003
Posted by mojodoctor on Saturday, May 16, 2009 8:34 AM
I think you're right Brumbles.
I found that two Douglas DB-7A, Havoc II's were converted to the twin tail configuration after France ordered them with the bigger Wright R-2600 engines in order to provide more stability. It didn't really improve anything, so they were reconfigured to the common single tail.
Posted by MQM107 on Saturday, May 16, 2009 8:45 AM
Beech Aircraft XA-38 Grizzly.
    October 2005
Posted by Brumbles on Saturday, May 16, 2009 8:50 AM
Wikipedia confirms Mike's answer: http://en.wikipedia.org/wiki/XA-38_Grizzly
I never think of Beechcraft as building military aircraft, especially not combat planes.  I thought there was a Douglas look about this one.
    September 2003
Posted by mojodoctor on Saturday, May 16, 2009 9:21 AM
As did I!
No wonder I couldn't find a photo of the twin tail Havoc. This one does have a Beechin' tail.
Get it? Beech,... Beechin',.... Uh, never mind! Wink [;)]
    March 2006
Posted by simpilot34 on Saturday, May 16, 2009 10:46 AM
LOL well I didn't expect this to go so fast!!!!!! Yes indeed it is the Beechcraft XA-38 Grizzly!!!! Mike the podium is yours!!!! Give us your best shot!!!!! Well done!Thumbs Up [tup]
Posted by MQM107 on Saturday, May 16, 2009 3:14 PM
Well to tell the truth I should have recused myself from answering this question as I am a 30 year veteran of Beech Aircraft. Heck I even remember the entry Beech had into what was won by the Cessna (brand X) T-37. So on that note ' what was the other contender for that ( the T-37) award? And just for extra points (not needed to be judged correct) if you are a reloader of ammunition, what is significent (SIC) about this airplane.
And for everyone who didn't see Beech in this plane, just think model 18 on steroids and you will.
    January 2009
Posted by F-8fanatic on Saturday, May 16, 2009 4:09 PM
I have seen this one, its in a museum in Wichita.  It was called the Beechcraft Jet Mentor, also known as the Beech Model 73.  First flew in 1955, it used a lot of parts from the T-34 Mentor, like the vertical tail.  It was actually not a bad design, flew with one engine and was quite economical as jets went back then.  But only one was completed and that one now sits, needing a complete restoration, on the field across from Boeing.
Posted by MQM107 on Monday, May 18, 2009 8:39 AM
There were at least three entries into the competition, Cessna,  Beech, and who was the third?
    January 2009
Posted by F-8fanatic on Monday, May 18, 2009 7:15 PM
If I remember right it was the Temco TT-1 jet.  It was doomed from the start because it was supposed to have the GE J85 engine, and instead it flew with another engine that had something like one THIRD of the intended power that the J85 would have had....
Posted by MQM107 on Tuesday, May 19, 2009 8:26 AM
That is absolutely correct. 15 were made and ended up with the Navy. The bonus question is that A man named Mike Dilliion who's company builds what are considered the best reloading presse's, owns one. But his is a Super Pinto with the J-85 and tip tanks from a Mitsubishi MU-2. Quite a little rocketship. Your up!
    March 2006
Posted by simpilot34 on Tuesday, May 26, 2009 11:09 PM
Whistling [:-^] F-8fanatic where are you????
    September 2003
Posted by mojodoctor on Sunday, May 31, 2009 10:28 PM
Bumpty bumpty bump,.... Bump City!
Posted by osher on Sunday, May 31, 2009 10:49 PM
Maybe we should have a rule: the winner has a week in which to post a new question, else, it goes to the floor?
If so, here's a question, from a documentry I saw a few months back, hope it's of interest: These two countries were allies, and both produced aircraft that looked very similar, and using similar engines.  Indeed, the first country even sent the other designs, but, they were never used.  Instead, the second country, just used some photographs as a design idea, but developed different engines, and bodies, even if, at a distance, they looked the same.  What's more peculiar is that, two rivals, in the second country, both managed to make engines and airframes that were unique, but still, at a distance, looked like the original from the first country.  I believe I'm right in saying that, of the second country's two designs, only one flew, and then just in prototype form, before both projects were abandoned.
Now try and name all 3 designs!
    April 2005
Posted by T_Terrific on Wednesday, June 3, 2009 11:00 AM
----snipped---
Sign - Off Topic!! [#offtopic]
That is one of the rules. See Page one of this forum, "Post-edit":
/forums/1/567093/ShowPost.aspx#567093
Tom T Cowboy [C):-)]
Tom TCowboy
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
Posted by osher on Wednesday, June 3, 2009 11:04 AM
Right!  In that case then, let's see if someone can answer my question!
    May 2009
Posted by modelbuilder12 on Wednesday, June 3, 2009 11:30 AM
f-86 was the first
MODELBUILDER12 "If the wings are traveling faster than the fuselage, it's probably a helicopter -- and therefore, unsafe."-Unknown "Tyrants have always some slight shade of virtue; they support the laws before destroying them." -Voltaire "Aim towards the Enemy." -Instruction printed on US Rocket Launcher
Posted by osher on Wednesday, June 3, 2009 11:34 AM
Nope!
    January 2009
Posted by F-8fanatic on Wednesday, June 3, 2009 9:31 PM
it almost sounds like youre referring to three aircraft from three different countries, actually.  First was the P-51 Mustang.  Second was the Martin Baker MB.5, and third was the Commonwealth Aircraft Corporation CAC-15 "Kangaroo".  All three look similar, the second and third look close enough that they could have been built by the same company.  Both of those used the Rolls Royce Griffon engine.  But they also both flew as well.
    March 2006
Posted by simpilot34 on Wednesday, July 1, 2009 9:49 PM
It's quiet, TOO quiet!!!!! Can I make a suggestion??? Maybe we should throw a lot of easy ones out here to get the ball rolling again!?
    April 2009
Posted by gmat on Wednesday, July 1, 2009 10:30 PM
Me-163 and the Mitsubishi J8M1 and perhaps the Kugisho/Yokosuka MXY-8 Akigusa Rocket Interceptor practice glider (Experimental Shusui Light Glider) or Yokoi Experimental Ki-13 Shusui Heavy Glider?
How about the ME-262 and the Nakajima Kikka (with Yokosuka helping in the design) and Nakajima Ki-201.
Best wishes,
Grant
Posted by osher on Thursday, July 2, 2009 3:57 AM
Close enough for me!  Basically, at the end of the war, the Japanese were developing two completely separate airframes and engines, which, in profile resembled the Me-262.  The most famous of these was the Kikka.  These two were unrelated to each other, but, also to the ME-262.  It's often thought, wrongly, that the German design was copied, but, actually, the Japanese were really just inspired by it, with it's shape offering clues, but, that's about it (the submarine with the actual plans was sunk).  The Japanese army and navy hated each other (sounds familiar), even developing rival ships, submarines, aircraft, etc.  As such, both Japanese designs were quite different, except in profile (although different sizes).
    April 2009
Posted by gmat on Thursday, July 2, 2009 7:25 AM
I'm not a regular participant in this thread, so I hope that I don't commit any faux pas. There are some very knowledgeable people here.
The Mustang and Thunderbolt have served in many theaters of operations, but, including post-war USAAF/USAF service, the Thunderbolt never served here, although the Mustang did. Where might this be? There could be various answers, but I hope not.
Best wishes,
Grant
    October 2005
Posted by Brumbles on Thursday, July 2, 2009 8:21 AM
In the Korean War?
If I win, someone else can pose the next question -- perhaps you, Grant?
I found an awesome pic online of four or five P-47s (F-47s by then, probably) of the Maryland Air National Guard flying in formation -- which is doubly cool for me because I live in the flight path of Martin Airport, outside Baltimore, where MD ANG A-10 "Thunderbolt II"s frequently fly in formation!
