Aircraft Trivia Quiz
    June 2009
Posted by Tango Juliet on Monday, January 16, 2012 9:39 AM
Yes.  Well done.  I was starting to think along the lines of a Bomber.  I know the B-52's had started carrying a rotary launcher for cruise missiles in the 90's about the same time they retired the Gunners, but it holds eight, and the B-2 holds twice that with two side by side bomb bays.  But we never referred to either one as "Cowboy", so I knew it wasn't those.
TJ Rohyans
Mobile, AL, USA
    December 2011
Posted by Luft Modeler on Monday, January 16, 2012 12:44 PM
I knew it had to be a russian aircraft though I was looking through Mig and Suhkoi and did not think to look at Tupolev. Good job F-8. This one had me thinking I was getting close at times.
    September 2011
Posted by Centhot on Monday, January 16, 2012 5:14 PM
There have been some interesting questions recently!
2012 A/B/C: 10/3/0 (Acquired/Binned/Completed)
    July 2011
Posted by MilitaryAircraft101 on Tuesday, January 17, 2012 5:07 PM
Definitely, I did start to think bomber, but well done F-8!
    January 2009
Posted by F-8fanatic on Wednesday, January 18, 2012 7:08 AM
Alright....
I am looking for an aircraft.  This was basically "the plane without a home".  This plane was built in small numbers.  It was built by one country, but not for that country's air force--rather, the entire production total was ordered by another country.  Current events at that time saw this order halted, though the planes were built anyway.  A second country stepped in and wanted the planes.  Most of them were instead shipped off to a THIRD country.  Its armament was basically similar to that of the early P-39 Airacobra.  It shared something up front with the F4F Wildcat.  The prototype had a critical problem in common with the FW-190.
    October 2007
Posted by Milairjunkie on Wednesday, January 18, 2012 11:58 AM
Vultee P-66 Vanguard?
Originally ordered by Sweden, order transfered to GB over fears of the Swedish aircraft being captured, ultimately going to China.
Powered by the P&W R-1830 like the F4F.
Suffered engine overheating / heat problems like some of the FW-190's.
    January 2009
Posted by F-8fanatic on Wednesday, January 18, 2012 5:05 PM
wow that didnt take long...yep, the P-66 alright.  over to you....
    October 2007
Posted by Milairjunkie on Wednesday, January 18, 2012 5:18 PM
Just sheer luck on that one, especially considering the usual "resource" wasn't available.
I'm out of time & questions at the moment, so first come, first served for the next one..................
    September 2011
Posted by Centhot on Thursday, January 19, 2012 4:14 AM
This aircraft was one of the best of it's era, certainly one of the fastest.  The aircraft grew out of an earlier one that had first taken to the air almost exactly a year before the war ended.  A small order was placed for this, but, due to the engine supply being mostly for another aircraft, there were production problems.  Instead, it was re-engineered for another engine, and in this guise was most successful, sort of.
Some of this new aircraft made it into service before the end of the war, but, none were operational by war's end.  Huge orders had been placed, for the French, British, and American air forces, with plans for production in America.
However, with war's end, so came the end of the orders.  Sadly, the company folded too.  Interestingly though, many ex-military machines were bought back, and converted, whilst others had long careers with many airforces, across many continents.  As a coda, after the original company folded, the company that bought them up re-engineered the aircraft again for different engines, selling them under it's own name.
    July 2011
Posted by MilitaryAircraft101 on Friday, January 20, 2012 4:28 AM
Hawker Sea Fury?
From Wiki
The first Fury to fly, on 1 September 1944, was NX798 with a Centaurus XII with rigid engine mounts, powering a Rotol four-blade propeller.  (Nearly 1 yr before end of war)
Second on 27 November 1944 was LA610, which had a Griffon 85 and Rotol six-blade contra-rotating propeller. By now development of the Fury and Sea Fury was closely interlinked so that the next prototype to fly was a Sea Fury, SR661, described under "Naval Conversion." NX802 (25 July 1945) was the last Fury prototype, powered by a Centaurus XV.
With the ending of the Second World War in Europe, the RAF Fury contract was cancelled and development centred on the Sea Fury. LA610 was eventually fitted with a Napier Sabre VII, which was capable of developing 3,400-4,000 hp (2,535-2,983 kW).  (New engine as a result of end of WW2)
As a result it became the fastest piston-engined Hawker aircraft, reaching a speed of around 485 mph (780 km/h).[6] (although a de-militarised Sea Fury holds the unofficial speed-record for a piston-engined aircraft in level flight at 547 mph).
    January 2009
Posted by F-8fanatic on Friday, January 20, 2012 6:37 AM
I dont think thats it, there is no American connection to that plane.  The question states that the design was supposed to be built in America, and that there were large American and French orders placed for the plane.  As far as I can recall, there were no such American orders for this plane, nor was it ever to be built in America.
    September 2011
Posted by Centhot on Friday, January 20, 2012 7:30 AM
Indeed, and Hawker's are still (sort of) around today.  Speaking of naval version, there was a floatplane version of this aircraft.
Total production was under 400 aircraft.
The aircraft company originally built motorcycles.  The company's name was changed at one point to being a shortened form of the original name, which was the name of the owner and chief designer.
In some ways, you might think of a later company, which had in some respects a similar experience, and half the same name.  That later company also built things other than aicraft, for which is it also famous.
    July 2011
Posted by MilitaryAircraft101 on Friday, January 20, 2012 4:36 PM
XA-38
    September 2011
Posted by Centhot on Friday, January 20, 2012 6:02 PM
No, this aircraft actually made production.
Here's another clue:
It had a single engine, originally a Rolls-Royce engine.  No one is sure how many of the original design, with the RR engine were produced, but between 360 and 380 were produced of the second engine (ironically, some of the re-engineered version later had the original engine!).
    July 2011
Posted by MilitaryAircraft101 on Saturday, January 21, 2012 2:44 AM
Well that cancels out the Dh.103 :( Proving a toughie Centhot
    September 2011
Posted by Centhot on Saturday, January 21, 2012 5:42 AM
OK, this aircraft was a fighter, but was often used for other purposes.  It was both single and twin seat, and it changed engines several times.  It was also a floatplane, and a civilian tourer.
For it's time it was one of the best, but the original production version was produced in small numbers, due to engine supply problems from RR.  A new engine was sourced, and the airframe slightly altered.  This was so successful that the American, British, and French wanted it, and the American to build it, along with the British original company.  This wasn't surprising, as it was one of the best of it's day, certainly one of the fastest, if not the fastest.
Huge numbers were ordered, too much for this company, so sub-contractors were brought in - and then the war stopped, after just a few were delivered.  Sadly the company folded a few years later.  Interestingly, it had a new life, as the people who bought the assets saw the potential, and it carried on for a while, under a new name.
Countries that used it include:
Belgium, Bolivia, Canada, Finland, Ireland (including one for a very special personal purpose), Japan, Latvia, Lithuania, Poland, Portugal, Spain, USSR (100 copies), UK
    September 2011
Posted by Centhot on Sunday, January 22, 2012 3:58 PM
Next clue: think of the Martin-Baker fighter series.  There's a connection in the name, as well as the history...
    September 2011
Posted by Centhot on Monday, January 23, 2012 9:35 AM
OK, another clue.  Finland's aircraft museum has a good extant example of this aircraft.
    October 2007
Posted by Milairjunkie on Monday, January 23, 2012 12:57 PM
There's are Martinsyde F-4 Buzzard at the Jyväskylä museum which seems to fit the bill?
    September 2011
Posted by Centhot on Monday, January 23, 2012 3:39 PM
We have a winner, phew!  Yes, the Martinsyde Buzzard.  One of the greatest aircraft of it's era, it would today be mentioned alongside Fokkers, Sopwiths, etc, but the war ended just before mass production began.  The fact it remained in service for another 21 years shows just what a fantastic design it was, and a tribute to Martinsyde.  The idea of 1,000's of British, French, and American Buzzards flying through the air would have been amazing.
Over to you...
    October 2007
Posted by Milairjunkie on Monday, January 23, 2012 4:48 PM
I spent too long looking at early jet aircraft & then Merlin powered stuff...........
Straightforward one now;
The most produced aircraft of WW1?
    September 2011
Posted by Centhot on Monday, January 23, 2012 5:32 PM
I'm guessing either Spad XIII or A.V.Roe's little beauty... but, Avro 504 I think.
    July 2011
Posted by SuperNova-SS on Tuesday, January 24, 2012 12:00 AM
Yeah, I'm pretty sure it was the SPAD XIII, but the Strutter and the Camel were high on the list as well.
I play World of Tanks! (Yeah, I'm a dork)If anybody has one of those kits with the WoT coupons inside, I'll be happy to take them off of your hands!   :-)
http://i1213.photobucket.com/albums/cc465/the_real_red_baron/60E0B8F7.jpg
    March 2010
Posted by Scorpiomikey on Tuesday, January 24, 2012 12:14 AM
Avro 504 - 8970 units produced.
Centhot called it first though.
Camel only had 5490 units.
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    October 2007
Posted by Milairjunkie on Tuesday, January 24, 2012 2:09 AM
The Avro 504 it is.
This guy obviously can't do it with chat up lines alone;
    September 2011
Posted by Centhot on Tuesday, January 24, 2012 5:42 AM
OK, here's mine.  This aircraft took part in a reasonably well known movie, in which it crashed landed in the mountains (but the people could escape through the roof).  The actual aircraft used then really did crash, in reality, around 21 years later, killing everyone on board.  What was the aircraft registration number?
    February 2011
Posted by PhilB on Tuesday, January 24, 2012 6:12 AM
On 25 January 1993, a TABA Fairchild Hiller FH-227 registration PT-LCS operating a cargo flight from Belém-Val de Cães to Altamira crashed into the jungle near Altamira during night-time approach procedures. The crew of 3 died.
    October 2007
Posted by Milairjunkie on Tuesday, January 24, 2012 7:40 AM
The first thing that came to mind was Flight 571, but was PT-LCS (522 / N7808H) used in the film, or was it HC-BUF (573 / N2784R)?
On a more important point, Alive (weather the film in question or not) was quite an impressive film, there is one part during the crash which is simply jaw-dropping - I'm sure you know the part I mean............
    February 2011
Posted by PhilB on Tuesday, January 24, 2012 7:49 AM
HC-BUF was w/o 28 October 1997 which seems to be a little outside the time frame of the question.
    June 2009
Posted by Tango Juliet on Tuesday, January 24, 2012 7:59 AM
Concorde 1977 Movie
Registration Number F-BTSC crashed July 2000.
TJ Rohyans
Mobile, AL, USA
