Aircraft Trivia Quiz
Posted by jeaton01 on Wednesday, September 19, 2007 4:08 PM
No, not the P-36, Tom.  Bret was on the right track.
John
    April 2005
Posted by T_Terrific on Wednesday, September 19, 2007 5:50 PM
 If Bret's "right track" was Russian, the name "Lavochkin" still lives as NPO Lavochkin, the successor organization, a Russian manufacturer active in aeronautical design and engineering.
They had a series of radial engined aircraft, including the La -5, La-7,  and the La-126.
Otherwise, the Polikarpov I-16 radial-engined fighter had a similar plan form to the I-17, but in profile, the I-17 was much sleeker.
Now after Polikarpov's death death on 30 July 1944 at the age of 52, his OKB was absorbed into Lavochkin, so it could be said his name lives on indirectly.
So do you duck hunt?
Tom Cowboy [C):-)]
Tom TCowboy
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
Posted by jeaton01 on Wednesday, September 19, 2007 7:35 PM
Well, I think I can hear the brain cells frying out there.  I neither duck hunt, nor have any congress with a canard.  Look closer to Bret's first guess, and think less aggressive.
John
    December 2003
Posted by skybolt2003 on Wednesday, September 19, 2007 9:16 PM
Less agressive - Yak UT-1, radial engine single seat trainer?
-Bret
Posted by jeaton01 on Thursday, September 20, 2007 12:01 AM
And this time the Duck has come down, as Groucho would say, as Bret has written the magic word.
It was Yakovlev's first design produced in series, beginning in December 1936 and ending in 1940, 1,241 were built.  It was designed as a sport plane and used as an advanced trainer for fighter pilots.  The UT-2 primary/advanced 2 seat trainer went into series production a few months after the UT-1.  Both had Shvetsov M-11 5 cylinder radials.  Here is a picture of the one in Yakovlev's museum, from their web site, below is the 1/72 model I built earlier this year from the Pavla kit in front of the UKAR  kit of the Tupolev ANT-25.  Neomega did a 1/72 kit in resin also.  I think it is "cute as a bug".
John
    March 2007
Posted by bondoman on Thursday, September 20, 2007 12:09 AM
-Bret
I think I feel a hangover coming on.
    April 2005
Posted by T_Terrific on Thursday, September 20, 2007 11:19 AM
Well, you see jeaton, down here in south Louisiana, we have vast wetlands where Americn waterfowl come down for the winter, and when a big fat mallard "comes down" to your blind, all nice and easy with his wings spread out, making a perfect target, and Tom T shoots him with his Brazilian-made $50.00 12 gage single-shot shotgun, we eats him for suppa, with various vegetables, greens hot fresh made bread and potatoes. Big Smile [:D]
So when the duck "comes down" here we are in for a nice mid-winter treat!. Wink [;)]
Tom Cowboy [C):-)]
Tom TCowboy
    December 2003
Posted by skybolt2003 on Thursday, September 20, 2007 2:07 PM
Cute as a bug it was – my question is about an aircraft that was it's contemporary and shared many of it's salient features. One of its distincitive features was its radial engine. Most multi-cylinder engines, like V's or boxers have an even number of cylinders while radials have odd number. Most single row radials are either 7 or 9 cylinder affairs for smoothness. This one, like the Yak had a 5 cylinder powerplant. Pretty unusual (there was at least one 3 cylinder radial as well).
Name this plane and its engine. Super bonus points if you can tell why a radial uses odd numbers. More bonus points, but not super bonus if you can come up with a 3 cylinder radial.
-Bret
Posted by wdolson2 on Thursday, September 20, 2007 4:12 PM
-Bret
 Don't know of any aircraft, but I did find that a German company named Konig made a 3 cylinder radial.  It's now called Zanzottera.
As to why radials have odd cylinders, I had never thought about it before, but thinking about the geometry, having an even number of cylinders would require that pairs of cylinders would be opposite one another and they would tend to buck each other.  With an odd number of cylinders, nothing opposes anything else.
 I guess I answered the bonus questions, but not the main one.
 Bill
Posted by jeaton01 on Thursday, September 20, 2007 7:44 PM
I'm thinking that any one of several light US aircraft might fit this.  The Ryan PT-22 with the Kinner is one, but there is also the Aeronca LC and the Culver Dart, powered by Warner, LeBlond, or Ken Royce 5 cylinder radials.  The reason for the odd number of cylinders in a single row radial is that there is a single throw on the crankshaft, and a four stroke radial will make two revolutions to fire all of its cylinders.  It's easier to get the valve timing and ignition timing done mechanically by firing alternate cylinders.  1,3,5,2, 4 is the firing order.  The 3 cylinder radial that was most common, even though it was pretty much a disaster, was the Szekely.  One of my uncles learned to fly in a Curtiss Junior powered by the Szekely, and he had a cable attached to all of the cylinder heads to keep them from going through the pusher prop when they broke.  I kid you not.
There was a six cylinder 4 stroke radial, the Curtiss Challenger, and it has fooled some people because there was no main bearing between the two throws of the crankshaft and at first glance it can appear that all six of the cylinders are in line, but they are not.  It is a twin row 3 in front 3 in back radial.  It wasn't a good engine because of the lack of the middle main, but it did power some Curtiss Robins.
It is possible to have 5 cylinders in an inline 4 stroke engine, Mercedes had a diesel with 5 cylinders.  I suspect it had irregular timing, like the Wisconsin V-4 industrial engine that used the same crank as an inline engine.  Two cylinders fired 180 degrees apart as is normal, but the other two were 90 and 270 degrees in interval.  It was not a smooth running engine.
With two stroke engines, any configuration is possible.  Detroit diesel sold I3, I4, I6, V8 and V12 cylinder versions of the V-71 series diesels.
John
    December 2003
Posted by skybolt2003 on Thursday, September 20, 2007 8:21 PM
John, very good answers. The engine question, the wildcard, is obviously very complicated and a lot of odd balls have existed. When I was a kid we had a 5 cylinder diesel Merc. Inlines are a little different. Harmonics, firing order, counter balances, bank angles et al.I didn't realize that Warner made a 5 jug engine. I thought they were all 7. For a good explanation of how a radial engine works, check out:http://www.radialengines.com/faq_section/index.htm#q2
The Szekely was the 3 cylinder I was thinking of - I think the cable was standard equipment even on cubs. Who would want to have a cylinder pop off and hit you in the face? # cylinder Anzani was another.
As for the main question - you are right, a lot of planes of the time fit the bill. But this one is a single seat, 5 cylinder radial powered plane that looks a *lot* like that Yak. And it wasn't powered by a Ken Royce (Le Blond is basically the same engine, right?) or the Warner . . .
Posted by jeaton01 on Thursday, September 20, 2007 10:40 PM
dodged that bullet.....
Yes, Bret.  LeBlond was renamed Ken Royce, after Ken and Royce's father bought Leblond.
John
    March 2007
Posted by bondoman on Thursday, September 20, 2007 11:58 PM
Audi made a five cylinder inline spark ignited engine. The claim as I recall was a shorter car.
I had a 3 cylinder Bug for a while: broken plug.
It's the 1936 Porterfield 35-70 Flyabout, for sure.
    December 2003
Posted by skybolt2003 on Friday, September 21, 2007 8:10 AM
No, it's not the Porterfield . . .
Like the Rearwins, which used the Ken Royce engines they manufactured, this plane was built by the same company that made the engine.
That 5 cylinder in the Audi was transverse mounted - it was an issue of how wide the car was and how much engine could they get. I remember the B rally cars (Killer Bees) in the eighties - that Audi was a monster. I watched Bobby Unser race it up Pike's Peak. The exhaust pipe was a big rectangle coming out the middle of the car with flames shooting out everytime he lifted the throttle. We were photographing it for Audi and Michelin. Its an amazing sight to see with no gaurd rails and sheer drop-offs.
Posted by jeaton01 on Friday, September 21, 2007 11:34 AM
Kinner Sportster
John
    December 2003
Posted by skybolt2003 on Friday, September 21, 2007 12:11 PM
 jeaton01 wrote:
Kinner Sportster
Right!  That's the answer I was looking for!  It looks an awful lot like the early Yak, don't you think?
-Bret
Posted by jeaton01 on Friday, September 21, 2007 3:28 PM
Drat!
Yes, I can see the resemblance, just kind of blown up a little.  I have plans for the Sportster in 1/6 scale for RC.  Looks like it was a fun airplane.  One of my friends did the plans when he scratch built a model of it.  Unfortunately the model met its demise some years ago while doing a loop, the battery bailed out through the open cockpit and you might say everything else went "downhill" from there.
New question later today.
John
    December 2003
Posted by skybolt2003 on Friday, September 21, 2007 6:36 PM
I can't wait for the next one . . .
So John, do you still have zero juliet echo?
Posted by jeaton01 on Friday, September 21, 2007 9:02 PM
No, I sold it about 10 years ago.  I used to commute from a farm strip near Woodland to Rancho Murieta when I had an office there.  At the time it was cheaper to fly it than driving a car that far.  Probably is one of the few 140's that was IFR legal.  I think it's somewhere in Texas now.
John
Posted by jeaton01 on Friday, September 21, 2007 9:06 PM
Okay.  There is a model which could be converted to this airplpane without too much fuss.  What was the first business jet developed in Witchita?
John
    December 2003
Posted by skybolt2003 on Friday, September 21, 2007 9:11 PM
I grew up in Fallbrook, I used to fly my commercial manuevers over a mesa above Murrieta. My friend who flies in Sport Biplanes at Reno (Phantom) used to practice up there too. Doesn't look the same now though.
-Bret
    December 2003
Posted by skybolt2003 on Friday, September 21, 2007 9:24 PM
Well, the Lockheed Jetstar is kind of considered the first business jet (and a very cool looking one I must say) but the Learjet 23 I think must have been the first Wichita bird . . .
Posted by jeaton01 on Friday, September 21, 2007 10:57 PM
Oh no, not those.  This was before the Lear.  There is some conflict in sources about whether this airplane flew in it's civilian guise, but a mockup and maybe a prototype was built and a marketing effort was put forth that was unsuccessful.
John
    December 2003
Posted by skybolt2003 on Saturday, September 22, 2007 12:38 PM
Well, Beech was trying to develop the Morane Saulnier Paris Jet, which went nowhere, but Cessna also tried to market a 4 seat version of their successful trainer the T-37.  It was designated the 407.  Given the T-37's reputation as one of the most ear-shattering planes around, I can imagine that might have had some role in the 407 never being successful...
-Bret
Posted by jeaton01 on Saturday, September 22, 2007 4:31 PM
Bless you, my son...
It's now your question.
John
    March 2007
Posted by bondoman on Saturday, September 22, 2007 11:33 PM
well I'm kind of PO'd because I answered the original ?? correctly before the caveats started to come in, but go ahead,
    December 2003
Posted by skybolt2003 on Sunday, September 23, 2007 8:28 AM
Sorry if you're mad - but I was thinking of the Kinner Sportster, not the Porterfield so John got it. The side questions are just for fun.
If you'd like to ask the next question, be my guest . . .
    March 2007
Posted by bondoman on Sunday, September 23, 2007 4:05 PM
Ah let me apologize... I didn't get it after all. Sometimes things don't look right in print. It is for fun so I'll chill.
BC
    December 2003
Posted by skybolt2003 on Sunday, September 23, 2007 8:39 PM
No, go ahead. Post the next question. Please . . .
-B
BC
    March 2007
Posted by bondoman on Sunday, September 23, 2007 11:27 PM
Thanks,
The Sud Aviation Caravelle was accepted by United Airlines after the addition of thrust reversers, among other changes. What method of short landings did this commercial airliner use prior to this?
