Tamiya thin cement and painting
    September 2003
Posted by out04 on Saturday, October 7, 2023 5:50 PM
How long do y'all wait after assembly (with Tamiya thin) before you lay down paint?
    February 2021
Posted by JimC2020 on Saturday, October 7, 2023 5:57 PM
at least an hour
cause then I'll sand it a bit if neccessary, prime, and then paint
    April 2020
Posted by Eaglecash867 on Saturday, October 7, 2023 6:47 PM
I'll usually wait at least overnight, to give the welded plastic enough time to fully re-harden.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
fox
    January 2007
Posted by fox on Sunday, October 8, 2023 11:05 AM
Ditto on overnight.
Stay safe.
Jim Captain
 Main WIP:
    March 2013
Posted by patrick206 on Sunday, October 8, 2023 3:35 PM
It depends on the size of the glue joint and the size of the parts attached. Tiny part and small amount of cement used, at least a few hours.
Large surface area and big parts, (wings to fuselage, or additional plastic strips for increased joint strength,) minimum of overnight. A little poke with a hobby knife tip will tell how hard the cement joint is, if it's still a bit soft, then waiting until a full cure has been reached is needed for the best results.
    August 2022
Posted by ThanosForever on Sunday, October 8, 2023 4:35 PM
Add me to the list of those who let anything that's been glued to sit overnight before sanding/priming/painting. I finally figured out a long time ago, after too many nightmares of parts getting damaged by manipulating them too soon after gluing, that modelling is just like golfing - patience pays off and hurrying things leads to disaster.
    March 2022
Posted by missileman2000 on Tuesday, October 10, 2023 9:00 AM
I wait two to three hours.
    February 2021
Posted by MJY65 on Tuesday, October 10, 2023 11:24 AM
A few hours for small parts, overnight for long seams.   OTOH:  If sprue goo is involved, sometimes a week or more.  Rushing is a sure way to find that ghost seam after painting, especially if using lacquer.
    October 2019
Posted by Tanker-Builder on Thursday, October 12, 2023 6:29 PM
Hmmmm:
    Usually a full day. To make sure the sticky stuff has completely gassed out and the joint has hardened.
    June 2009
Posted by jimbot58 on Saturday, October 14, 2023 9:33 AM
Just seems that so much of our build time is waiting for glue or paint to dry...
On my workbench now:
It's all about classic cars now!
Why can't I find the "Any" key on my keyboard?
    February 2021
Posted by JimC2020 on Thursday, October 19, 2023 10:09 PM
ThanosForever
Ha ha, too true!!
    May 2009
Posted by Pawel on Friday, October 20, 2023 7:17 AM
That's what jobs are for - you glue something, go to work, and when you return it's ready to paint, or sand or whatever :-)
www.vietnam.net.pl
