F-4F Phantom II West German White Horse 6 May - DONE!
Posted by IBuild148 on Monday, March 15, 2010 9:50 AM
Good Morning All,
I am building my first Phantom, a Revell kit and so far no major problems.
I have no technical experience with this aircraft. I just like its storied past, the way it looks and have always wanted to build one.
Following are 2 PICs with questions that I hope someone can answer.
             IMG_4170.jpg picture by xlt2002ms
             IMG_4173.jpg picture by xlt2002ms
     Thanks
IBuildOne48
Teach modeling to youth!
Scalefinishes.com
http://i712.photobucket.com/albums/ww122/randysmodels/NMF%20Group%20build%20II/Group%20Badge/NMFIIGBbadgesmall.jpg
Posted by berny13 on Monday, March 15, 2010 10:10 AM
The first picture is the Aux Air Doors.  They would be open when the gear is down.  The inside color is flat insignia red.
The second question is the blast panels were made of titanium and would get very dirty from the exhaust.  Use MM titanium with a mixture of steel to lighten up the paint.  After it cures use a wash of black to cover the panels to simulate exhaust stains.
The burner can secondary AB eye lids should be painted dark titanium on the outside.  Inside the eyelids should be painted the same color but dry brush with a light mixture of exhaust and black.  The primary AB eyelids should be painted dark titanium with a wash of dirty black.  Inside the exhaust area is a light to dark green AB liner drybrushed with light gray and black streaks.  If you want to show a high time engine the AB liner will be a dark or ash gray color, drybrushed with darker gray and black.
Above the blast panels are the shingle panels and they should be painted in steel and titanium mix.  They did not get dirty like the blast panels but would crack very easy and had to be changed.  So if you want lighten individual panels to reflect this.
I hope I was able to help.
Berny
 Phormer Phantom Phixer
On the bench
    October 2004
Posted by Ben Brown on Monday, March 15, 2010 10:20 AM
You'll probably hear from  couple of guys here who actually worked on F-4s, but perhaps I can help a little. The openings under the wing are auxilary air inlet doors that would open when the landing gear was down. IIRC, they'd also snap open when the jet was shut down, so you pretty much always see them open on operational F-4s. Museums usually close them. The insides of the doors were insignia red, and the underside of the engine was various metallic colors. The airframe parts in that area seem to be zinc chromate or Interior Green.   There used to be a company that sold a neat little resin insert for that area, but they're long out of business.
For the areas around the afterburner nozzles, I'd start with Steel and then darken things with Exhaust. The real jet was mostly stainless steel and titanium in that area.  If you look in the F-4, RF-4, and QF-4 sections here, you can see there was quite a bit of variation in the colors:  http://www.primeportal.net/the_airstrip.htm   5057 Phantoms is also a good source of F-4 pics, but the search doesn't seem to be working: http://www.5053phantoms.com/index-Dateien/frame.html
HTH.
Ben
    October 2004
Posted by Ben Brown on Monday, March 15, 2010 10:22 AM
Bernie was one of the guys I was talking about! Big Smile
Ben
Posted by IBuild148 on Monday, March 15, 2010 10:40 AM
Ben and Berny,
You both "ROCK"Bow Down! Thank you so much for the quick reply and the in depth information. I will post more pics as I progress.
Have a Great Day!
IBuildOne48
Scalefinishes.com
    March 2004
Posted by Mikeym_us on Monday, March 15, 2010 3:02 PM
IBuild148
Good Morning All,
             http://i706.photobucket.com/albums/ww68/xlt2002ms/IMG_4170.jpg?t=1268664106
             http://i706.photobucket.com/albums/ww68/xlt2002ms/IMG_4173.jpg?t=1268664501
     Thanks
Which one are you building? The F-4C or the F-4J? and if it is the Charlie model are you doing it in SEA camo or ADC gray? BTW if you do SEA camo you could try painting it ADC Gray first and then put the camo on top as was done on the actual birds. BTW Testors MM FS16473 Aircraft gray is also ADC Gray so if you have any of that laying around you are good to go.
Hmm never mind That looks like a Hasegawa bird in Revell packaging Probably a Echo model.
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
    January 2006
Posted by RedCorvette on Monday, March 15, 2010 3:39 PM
The wing has slat actuators so it has to be an -E.  Revell/Monogram never did a slatted -S.
Mark
FSM Charter Subscriber
    July 2004
Posted by stikpusher on Monday, March 15, 2010 3:57 PM
I'll just add a couple shots that I took of the afterburner off the F-4C at the Seattle Museum of Flight
Hope these will help.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by IBuild148 on Monday, March 15, 2010 6:43 PM
Mikeym_us,
It is this Revell Kit 04522, . It says that it will build an F-4F for the German AF, "35 Jahre JG74 Molders.
I wanted to do a USAF camo theme with AM decals but like I said, I do not have the information/pictures to find the decals that would make an "F" so I decided to build OB.
IBuildOne48
Scalefinishes.com
Posted by IBuild148 on Monday, March 15, 2010 6:48 PM
stikpusher,
Always great to here from you and thanks a bunch for the awesome referance pictures. I have been to that museum several times during my business travels to Seattle.
Thanks
IBuildOne48
Scalefinishes.com
    March 2004
Posted by Mikeym_us on Monday, March 15, 2010 7:56 PM
IBuild148
Mikeym_us,
It is this Revell Kit 04522, http://www.tstrains.com/catalog/DSCN6481.JPG. It says that it will build an F-4F for the German AF, "35 Jahre JG74 Molders.
I'm afraid there are no American F-4F's only LuftWaffe F-4F's the F-4F was the export model of the F-4E hence the nose gun. So basically it is the same as a E model on the outside the only difference would have been the cockpit.
Posted by IBuild148 on Monday, March 15, 2010 8:58 PM
Mikeym_us,
OK. Staying with the German aircraft can I use this scheme and decals?
F-4F Phantom II West German White Horse / West German Bundesluftwaffe F-4F in nonstandard 35th anniversary scheme for JG72 'Westfalen', 1996
                                      1:48 Eagle Strike Decals - F-4F Phantom II West German White Horse #48268
IBuildOne48
Scalefinishes.com
    March 2004
Posted by Mikeym_us on Monday, March 15, 2010 9:11 PM
Yeah you can use that scheme on your F-4F.
Posted by IBuild148 on Friday, March 19, 2010 6:29 PM
When I initially bought this kit it was because I wanted to build a Phantom. Since that time I have learned quite a bit from GOOGLE and here on FSM from former posts and replies.
So far this Revell kit has given me no problems and it has been a delight to assemble. After doing a search for decals I have selected Eagle Strikes, West German Bundesluftwaffe commemorating the 35th anniversary of JG 72 with the galloping white horse.
However I am hoping someone can help me with the "RED' and "BLUE" colors. Eagle strike says that these where nonmilitary colors and I buy that.
Following are two links of this aircraft along with my photo. They look "FLAT". Can anyone share a color match?
http://www.planepictures.net/netshow.php?id=784269
http://www.planepictures.net/netshow.php?id=784280
            001.jpg picture by xlt2002ms
More to follow!
IBuildOne48
Scalefinishes.com
Posted by IBuild148 on Saturday, March 27, 2010 9:41 AM
Guten Morgen,
Following are 3 photos of where I am with this build. 1 is the real aircraft I am building the other 2 are 1 primed and 2/3 where I have laid the Flat White down.
I was trying to find the official RAL colors used for this aircraft and I even emailed Bundeswehr and did receive an e-mail from a Sergeant Major telling me that, "There are no documents available concerning the former aircraft."
            12258131361.jpg picture by xlt2002ms
With that said, I have decided to use Tamiya's Flat White, Flat Red and Blue thinned with white to come close.
Here its primed:
      F4Primed.jpg picture by xlt2002ms
Here it is with the Flat White:
           IMG_4212.jpg picture by xlt2002ms
           IMG_4214.jpg picture by xlt2002ms
Next up is the Flat Blue.
Until then thanks for looking!
IBuildOne48
Scalefinishes.com
    August 2009
Posted by A10wrthg on Saturday, March 27, 2010 9:44 AM
wow looking goodYes
NYFAIM
Posted by IBuild148 on Tuesday, March 30, 2010 11:24 AM
Off to the paint shop to lay down my "special blend" of the blue. The taped off area is painted flat white.
          IMG_4220.jpg picture by xlt2002ms
         IMG_4218.jpg picture by xlt2002ms
Will post "positive" results soon!
Thanks for checking in!
IBuildOne48
Scalefinishes.com
Posted by IBuild148 on Tuesday, April 20, 2010 11:42 PM
Its been a few weeks since my last post were I was going to paint.
Unfortunately my feeble attempt at mixing the colors failed so I contacted ScaleFinishes.com, Jameston Kroon to see if he could.
He did and I well am pleased with the results.
           IMG_4297.jpg picture by xlt2002ms
           IMG_4299.jpg picture by xlt2002ms
           IMG_4300.jpg picture by xlt2002ms
More to follow.
IBuildOne48
Scalefinishes.com
Posted by Wingman_kz on Wednesday, April 21, 2010 12:09 AM
Very nice paint work. I'll be watching for updates.
Tony
Posted by IBuild148 on Tuesday, April 27, 2010 10:52 AM
Following is an update on this build. As mentioned earlier the 2 challenges that I foresaw where the colors and the "Large" Eagle Strike decal for the underside of the this aircraft.
The color issue was solved by scalefinishes.com. Once I laid the paint down my confidence grew.
After careful thought on how to place this decal because the auxiliary doors where in the open position and you only get one shot, I think it turned out An over abundance of Micro Sol also help.
                   IMG_4312.jpg picture by xlt2002ms
Now onto the upper fuslage decals.
Comments, suggestions, thoughts welcome.
IBuildOne48
Scalefinishes.com
    March 2008
Posted by Dirkpitt289 on Tuesday, April 27, 2010 11:20 AM
WOW, what a great job on the paint scheme. I can't wait to see the rest.
Dirk
On The Bench:
B-17F "Old 666" [1/72]
JU-52/53 Minesweeper [1/72]
Twin Me 262's [1/72] Nightfighter and Big Cannon
Posted by Wingman_kz on Wednesday, April 28, 2010 3:28 AM
Man I bet that was scary. hehe Good job! Carry on.
Tony
Posted by IBuild148 on Wednesday, April 28, 2010 12:45 PM
Dirk,
Thanks for the "WOW"! Motivation is a good thing!
Tony,
It was scary. Especially after my wife who usually doesn't take that much of an  interest even said, "why is it so wrinkly?"
Here is todays update:
         Before
          IMG_4318.jpg picture by xlt2002ms
         After
         IMG_4324.jpg picture by xlt2002ms
Until next time.
IBuildOne48
Scalefinishes.com
    October 2009
Posted by Medicman71 on Wednesday, April 28, 2010 2:17 PM
Very cool paint and decal job. It looks awsome!!!!
Building- (All 1/48) F-14A Tomcat, F-16C Blk 30, He 129
Posted by Wingman_kz on Thursday, April 29, 2010 3:41 AM
Why is it so wrinkly? Oh boy, that inspires confidence!(No offense to your wife)
Well, she's sure dressed to impress now. And that actually looks like a lot of fun. Scary. But fun. Keep up the good work.
Tony
Posted by IBuild148 on Thursday, May 6, 2010 9:51 AM
I am calling this one done. Being my first Phantom I am now hooked!
Matter of fact I bought a Monongram Black Bunny kit on E-Bay and when that arrives I will start on it.
Thanks to all of you who provided input and technical answers.
                         http://i706.photobucket.com/albums/ww68/xlt2002ms/12258131361.jpg?t=1269700489
                         IMG_4343.jpg picture by xlt2002ms
                        IMG_4350.jpg picture by xlt2002ms
                        IMG_4346.jpg picture by xlt2002ms
                       IMG_4345.jpg picture by xlt2002ms
                      IMG_4349.jpg picture by xlt2002ms
Keep 'em Flying
IBuildOne48
Scalefinishes.com
Posted by Gamera on Thursday, May 6, 2010 10:05 AM
WOW! Now that's a phantastic phantom!!!
Great work!!!
Posted by IBuild148 on Thursday, May 6, 2010 4:52 PM
Gamera,
Thanks for the WOW!
IBuildOne48
Scalefinishes.com
    October 2009
Posted by Gregbbear on Thursday, May 6, 2010 6:21 PM
That is one awesome bird!  You did a fantastic job.  That is a really cool paint scheme.  Thanks for sharing.  Now back to filling and sanding my own F-4.....
Cheers,
Greg
- yat yas!
Posted by rjkplasticmod on Thursday, May 6, 2010 6:26 PM
Phabouless Phantom.  Very nicely done Yes.
Regards,  Rick
