Revell 1:32 Beaufighter
    November 2004
Posted by brain44 on Monday, October 27, 2008 8:12 PM
I picked this up for practically nothing on EvilBay, and once I started it, I can see why....Disapprove [V]  I decided that it would be a good candidate for a scratchbuilt front office, as it didn't have anything except decals for instruments.... here are a couple of pics of the results thus far - not "rivet counting" accurate, just wanted to give it some visual interest- I used the decals as a template and locator to arrive at this:
Here are the same pieces plus the engines painted and detailed a bit:
And the cockpit sidewalls with alittle plumbing added:
And here is the fuselage buttoned up
and the port wing installed - the wing is a 3 part affair that is a real p.i.t.a. to get together!
As always, constructive comments and criticism are always welcome!
Brian  Cowboy [C):-)]
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
"I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these things to other people and I expect the same from them." John Bernard Books (The Shootist)
    September 2003
Posted by Daywalker on Monday, October 27, 2008 8:21 PM
Looking good Brian!
I'm with you- generally don't superdetail cockpits as long as I can closely approximate the detail.  Looks like you're well on your way here.  Just looking at the instructions with the wing parts broken down like they are gives me the heebie-jeebies.  Good luck with that one Brian! Thumbs Up [tup]
Frank
    October 2007
Posted by Summit on Monday, October 27, 2008 8:56 PM
Here Brian - I can probobly dig up some more pics for you Whistling [:-^] Smile,Wink, & Grin [swg]
BF-1 Really though, I like what you have done so far Thumbs Up [tup]
Sean "I've reached nearly fifty years of age with my system." Weekend GB 2008
    February 2007
Posted by DesertRat on Monday, October 27, 2008 9:47 PM
Well it's definately looking good so far, Brian! I never did like getting a kit- only to find out that its IP was just a decal. It seems..... I dunno, a little too second dimensional for my tastesWhistling [:-^]
Warmest regards,
Roger
    January 2015
Posted by Aggieman on Monday, October 27, 2008 9:55 PM
Brian, nice job so far!
That was the exact kit that got me back into the hobby back in '95.  I had always liked the Beaufighter as a youngster but had never encountered a model of it any where.  The stores in my area always seemed to stock the same Monogram and Revell kits but I don't recall ever seeing the Beaufighter.  So in '95 when I saw it on a shelf at a KMart, I snapped it up (and threw in 5 other kits for good measure), and my journey to the Dark Side, er, wrong movie, my return to the hobby was complete.
    June 2008
Posted by Hans von Hammer on Monday, October 27, 2008 10:21 PM
Built that very kit not 4 months ago.  I'd been carryin' it around for 15 years in my various moves, finally decided to tackle it... It went together pretty well, the wings were a breeze with the locking tabs.. The only real issue was the "removable" cowling panels...
I, too, super-detailed the cockpits, and am the only one who knows that... With the yoke in place, the panel is next to invisible except for a the small areas below the yoke on each side.  I may yet pop it off and cut open the hatch..  Can't see anything in the rear cockpit...
If I had it to do over again, I'd still detail the front cockpit, but I'd re-do the seat-pan.  The Beau didn't have that "padded" seat, it had a pan-type seat that the seatpack parachute fit into with the pilot inserting a cushion between his 'chute-pack and arse... Same with the R/O's seat... I'd also convert it to an FAA "Torbeau"  and vac a new rear "bubble" to mount the .303 "scare-gun"...  Overall, the Revell Beau is a good kit (especially for 1974) that is a scratch-builder's delight...  Those radials and the great-big wheel bays are just beggin' for it...  One thing I found during it's construction was that the gear is rather fragile, so watch out for that.  Once they're together and mounted and the cement is FULLY cured, they hold up well... Just make sure that the glue is SET before you put the plane on it's feet..
    January 2007
Posted by trexx on Tuesday, October 28, 2008 4:18 PM
A great kit! One of my favs from the past!
Hammer, soooo what you're saying is you've already completed it?
I've only got a photo opf my old one as the model is long gone now.
This is an Polaroid photo of mine on my parents driveway in front of some juniper bushes. Polariod's were swell. Instant photography. (OMG from the olden' days... HA!) I used to switch up the household vacuum cleaner and make it blow my propellors around for shots like these. Great fun.
When I built mine back in the '70s. (Revell 1/32) I cut the radar operator's head off and reattached it so he was looking out the side. (my first modified figure!)
Fun kit, REAL BIG, TOO!
    November 2004
Posted by brain44 on Tuesday, October 28, 2008 7:56 PM
Thanks for the kind words, everyone!  This is actually a fun and challenging build, giving me a good workout of my meager skills!
Frank, I agree with you on superdetailing, but I just can't abide a 'pit with just a decal or worse, nothing at all, it's like waving a red flag in front of a bull.....
Sean, thanks for the pic, I have a color version of that view - man, that 'pit is sure COLORFUL....
Roger, thanks, bro, btw, is the Patrol stuck with that HH-60 now instead of the Hughes 600s and NOTARS?
Steven, apparently this is a very in-demand kit, so I guess I got lucky - only one other bidder and no "war" in the last minute.  The kit cost less than the shipping $11 total!
Hans, I hear what you are saying, but you know the work is there, and that is what it's all about to me.  Having seen your work, I am very impressed and really appreciate your input - I never thought about the FAA version, just the RAF.
Trexx, that is acool idea for the prop spin, and it looks so great in a pic....I gotta try that!
    February 2007
Posted by DesertRat on Tuesday, October 28, 2008 9:00 PM
If I'm not mistaken, the Patrol has nothing but the 600s. Ever since they created CBP, the -60s are flown by customs guys in blue uniform.
   At least that's what I understand. But don't quote me on itWink [;)]
Either way, I'll be getting my fill of the Blackhawk once I get back to drilling status with the Guard. But I have seen kits of the -60s in Customs markings. I've got the rolodex spinning in my mind on that one.....
Warmest regards,
Roger
    December 2005
Posted by fantomfixer on Wednesday, October 29, 2008 8:15 AM
I vaguely remember coming across an AM site that sold generic instrument decals and bezels in various scales for cockpit scratchbuilders.  But for the life of me, I can't seem to find it.  Can anyone point me in the right direction?  Sounds like that would be just the thing for a project like this.
With the growing popularity of the 1/32 Revell Beaufighter, maybe someone will come up with a line of AM to add some much-needed detail to the cockpit.  Here's hoping!
    November 2004
Posted by brain44 on Wednesday, October 29, 2008 10:05 AM
When I left SDC for WRODDP, we had mostly 'Nam surplus OH-6As, two NOTARs, one A-Star and a couple of Hueys.  No one wanted to fly the A-Star or NOTARs, and few liked the huey (too big for patrol duty), so I have nearly all my observer time in them.....sure do miss flying up the canyons at night....
    November 2004
Posted by brain44 on Wednesday, October 29, 2008 10:13 AM
I think you might be remembering Waldron, or possibly Mike Grant (Excellent decal instruments).  Waldron was bought out by Brookhurst Hobbies http://www.brookhursthobbies.com/, I believe, and Mike Grant is still in business and has a good website http://www.mikegrantdecals.com/
    May 2006
Posted by Edgar on Wednesday, October 29, 2008 11:31 AM
Keep an eye on Model Design Construction; a gentleman, by the name of Derek Bradshaw, is working on a Beaufighter interior (plus Spitfire 1/32nd 21/22/24 wings, and a 1/32nd Tempest V.)
Edgar
    June 2008
Posted by Hans von Hammer on Wednesday, October 29, 2008 9:57 PM
I wouldn't say completed, since it's still got a diorama to go into, but it's 99%... Needs new decals and the weathering needs to be completed, but yeah, the build is done...
    June 2008
Posted by Hans von Hammer on Thursday, October 30, 2008 1:28 AM
I like the FAA paint better...
    May 2006
Posted by Edgar on Thursday, October 30, 2008 2:31 AM
That's Coastal Command (still RAF,) not FAA.  On Beaufighters the suffix "c" denoted coastal use, while "f" was fighter.
Edgar
    November 2003
Posted by tempestjohnny on Thursday, October 30, 2008 5:54 AM
Nice work Brian.  The additions in the cockpit really give it an extra dimemsion of detail.
    November 2004
Posted by brain44 on Thursday, October 30, 2008 10:17 AM
Thanks for the great info, Edgar!  I will look up MDC, sounds interesting, and the clarification on RAF vs FAA answers some questions for me!
    November 2004
Posted by brain44 on Thursday, October 30, 2008 10:19 AM
Thanks for the kind words, John!  The Beau has always been a favorite of mine, one of Britain's finest!   I hope to do her justice!
    June 2008
Posted by Hans von Hammer on Thursday, October 30, 2008 11:03 AM
Edgar
Arrgg..... You're right, and I knew that... Sorry about the brain-cramp....
    February 2007
Posted by DesertRat on Thursday, October 30, 2008 1:15 PM
I heard alotta stuff they had back then was Vietnam era surplus. But I'd definately be surprised if any of that stuff was still around
Warmest regards,
Roger
    November 2004
Posted by brain44 on Thursday, October 30, 2008 7:45 PM
Here's a shot of one of my old rides.....
    February 2007
Posted by Geomodeller on Thursday, October 30, 2008 9:36 PM
Looks good so far.
There was an excellent construction article for this kit in an old Scale Models magazine that you should try to get hold of if possible. When I say "old", I mean probably 1970's or 80's, so it might be difficult to track down. I have it at home in Australia but unfortunately I won't be back there until Christmas. I'd be happy to scan it for you when I return, but it looks like you will be finished the model before then.
One comment though - the interior green that you used looks more like the US Interior Green and nothing like the British colour (a pale grey-green)... or is that just the photos playing tricks?
    February 2007
Posted by DesertRat on Thursday, October 30, 2008 10:19 PM
Guess I woulda expected more predominant markings there, but it is a sweet ride nonetheless...
I can almost hear the "Magnum PI" theme song playing nowWink [;)]
Warmest regards,
Roger
