1/72 XB-70
    January 2010
Posted by wedfactory on Sunday, February 14, 2010 11:39 AM
Now for the build comments. After taping the kit together I have the following comments on construction.
First the is the connection between the cockpit and "goose neck". With a little care the connection should be no problem
The first problem I came across is the 4 wing panels. On my kit one of the top wing panels is warped and will take a little care to get to flatten out...
If I can successfully get this worked out then the goose neck to upper wing panels shouldn't be to hard. The lower wing panels will take quite a bit of work to get to lay right. The connection seems to be a bit awkward. I will have to spend some time here to get it right...
There are also 4 molding marks that will need to be sanded off, (no biggie there) and as with SR-71 models there will be quite a bit of pudding along the wing leading edge to hide the seam. I believe if you get the wings done well, the rest of the kit will fall together....
Hope this helps you guys....
wedmodelfactory.com
On the workbench: 1:48 F-15 / 1:48 F-14 / 1:48 B-25 / 1:48 Rafale B / 1:48 AR-234 / 1:48 Stuka / 1:48 A-10 / 1:48 KI-46 / 1:72 XB-35 / 1:72 SU-24 / 1:72 X-29 / 1:72 MIG-37 / 1:48 HO-229 / 1:32 HE-162 / 1:48 F-111
    February 2006
Posted by DantheMan85 on Sunday, February 14, 2010 5:20 PM
Wedfactory, your comments are pretty much what I saw when I did a dry test fit of mine.
On my Work Bench: Tamiya Ford GT 1/24
Up Coming: ?
