This is the Hasegawa 1/32 scale Kawasaki Ki-61-I hei Hien ( Tony) converted a Ki-61-II kai Hien “bubble-top”.
I always liked the Kawasaki Ki-61-II Kai Hien “bubble-top” and had been dreaming about converting the Hasegawa kit into one but the main problem was the so-called “clear parts” which I could not make myself. So when I saw that Alleycat made a resin conversion Ki-100 for the Hasegawa kit I mailed them and asked if I could buy a Ki-100 canopy from them. After several emails telling my intention with use of the canopy, I could purchase one for GBP 7,50 ( including postalcost)
Before I could start with the kit I had to finish two other kits; a Tamiya A6M5 Zero and the Hasegawa Myrt both 1/48 scale. After done the two I noticed Alleycat had a resin conversion Ki-61-II Kai, and I thought of choosing the easy way and buy their conversion kit. If I was a rich man I would……
But buying the conversion kit AND the Hasegawa kit as a donor kit would not please the misses…..
Modifications on this kit; - made the nose-section of the plane longer, filled the gap with Tamiya white putty and Evergreen, sanded off the “hump” on the cowling, build a larger air-intake.
Cut off the “back” of the plane and filled it with plastic and sheets of Evergreen.
The vertical stabilisor is enlarged with Evergreen and white putty.
The canopy I bought from AZ models and it is part of their Kawasaki Ki-100 resin conversion kit.
Everything is painted except for the numbers on the tail, thes come from a 1/48 scale Zero.
Best regards from the Netherlands;
Ulrich
![](http://img863.imageshack.us/img863/5536/71555883.jpg)
![](http://img263.imageshack.us/img263/3703/54527965.jpg)
![](http://img651.imageshack.us/img651/5796/a4aaaa.jpg)
![](http://img685.imageshack.us/img685/3431/a4bg.jpg)
![](http://img651.imageshack.us/img651/1436/a11ci.jpg)
![](http://img8.imageshack.us/img8/7243/80009327.jpg)
![](http://img146.imageshack.us/img146/2755/b01ac.jpg)
![](http://img52.imageshack.us/img52/7015/sdc11428mi.jpg)
![](http://img15.imageshack.us/img15/3010/sdc11429e.jpg)
![](http://img6.imageshack.us/img6/8262/c1eh.jpg)
