1/48 Revell F-15E Progress Thread
    June 2013
Posted by bvallot on Thursday, April 3, 2014 11:02 PM
Maybe you've mentioned this previously somewhere that I've overlooked, but what kind of thinner have you used with your oil paints?
On the bench:
Tamiya F4U-1  Kenneth Walsh
    February 2014
Posted by dflu78 on Friday, April 4, 2014 12:01 AM
Absolutely beautiful work. This kit is a real hidden gem considering you can get it for cheap at Hobby Lobby or Michael's. I built it last year and I'll be building it again now that I've gotten over my fear of Alclad. You're work on the rear is superb. As far as those things that go bang bang....wow...some of the best I've seen.
    December 2006
Posted by Fly-n-hi on Friday, April 4, 2014 1:03 AM
Dean & T3ch, thank you very much!
bvallot
I didn't mention it.  I used Mona Lisa Odorless turpenoid.  Although, I have used this technique with a few other odorless turpenoid brands so I'm not sure it really matters.  Mona Lisa is just what I happen to have now.
dflu78
dflu78, thanks alot!  Yeah, this is a great kit considering that you can routinely get it for $20-$25 on ebay, too.  In fact, I got this very kit off of ebay for $19.
    December 2006
Posted by Fly-n-hi on Friday, April 4, 2014 1:31 AM
Alrighty, here's where the rubber is meeting the road.  I mentioned several pages back that my intention was to take little bits of weathering from several different pics of Mud Hens and use them together on this build.  The result would be a plane that will have a fictional (and perhaps unrealistic) weathered look to it.
Generally speaking, these planes do tend to be relatively clean.  Only occasionally are they filthy...but every now and then they are.  I've taken a bit of artistic liberty in my weathering because, frankly, I enjoy doing it and I really like other people's builds that have convincing weathering.  Also, I find clean to be fairly boring.  As a result I'm at a point where the weathering on this build is a little more Navy like than Air Force.
So, here's where I'm at now.  There are about 4 layers of additional weathering in these pics.  I tried to keep it realistic in the sense that the dirty areas are places that normally get dirty...I just amplified them a bit.  Tell me what you think:
In the pic above you can see that I've used a silver Prismacolor pencil to draw the scratch marks on the in flight refueling door. I did this in the gun muzzle, too, but you can't see it in any of these pics.
The pic above shows how shiny the Alclad II high shine paint is.  I'm very happy with how it turned out.
One area that does seem to be commonly dirty is the area around and aft of the landing gear.  I really made an effort to make this convincing.  And you can see that I've attached the SNIPER XR pod.
I'm sure you've noticed that I have attached the gear and the Royal Resin wheels.  I needed to sand them down a bit because apparently I didn't do a very great job cutting them out of their casting blocks.  Also, the left wing sat about 2mm higher than the right wing.  I was scratching my head over this one considering the wings are molded with the upper fuselage partHuh?.  So I sanded the left wheel down a bit more.
I've attached the 600 gallon tanks and the GBU-31 to the pylons.  Sorry for the blurry pic above.
You can't really see it in the pics but I re masked the windshield and touched up the ragged frame.
Also, I forgot to post pics of the finished fuel tanks (back when I finished them) but several pics of Mud Hens show them carrying tanks that are painted Light Ghost Grey so I used those instead of the more common Gunship Grey tanks.
Personally, I'm pretty happy with the overall results in the above pics.  But like I said earlier...tell me your opinions.
    February 2014
Posted by T3chDad® on Friday, April 4, 2014 6:43 AM
Wow!....keeps getting better.
  On the bench: Between Builds...
Dre
    June 2007
Posted by Dre on Friday, April 4, 2014 8:21 AM
I would really like to see this model in person.   The further weathering is just sublime.
    December 2010
Posted by DWood538 on Saturday, April 5, 2014 5:59 PM
I've been following this thread since it started and it's really turning out great. I love build threads because I can learn new techniques, and yours especially has been pretty inspiring because I'm working on an eagle too. If it's not too much trouble could you just briefly explain the most recent weathering layers you've done (with the amber color and such), because it looks amazing and I'd love to learn how to do that.
-Derek
    September 2013
Posted by Dean30 on Sunday, April 6, 2014 12:55 PM
Honestly that is one of the best looking 1/48 modern fighter aircraft I have see built by anyone.
    December 2006
Posted by Fly-n-hi on Sunday, April 6, 2014 3:01 PM
T3chDad®
Dre
Dean30
Thanks alot, guys!  There's still a bit left to do so wish me luck!
DWood538
Thank you!
The additional layers are just filter layers that are a mixture of about 90% thinner and 10% color.  These layers are built up very slowly.    For example, the yellowish color is thinned out then sprayed on in a way so that you are just misting the surface.  It can also be brushed on but this is for general coverage.  This dries quickly since it is mostly thinner in the first place but you can use the air coming out of your AB or you can use a hair dryer to speed things up.
In the pics above I built up the yellow color in about 3 layers so that tells you that it really was very thin!  The trick is to build up slowly so that the paint is more translucent.  That helps give it that natural look.  Plus, with some of the layers I would add a drop of black to give it a slightly different dirtiness.
Just keep building up until it has the look you want.
Let your colors dry completely before applying a different color.  I usually waited until the next day to apply the following color just to make sure the colors did't bleed into each other.
    December 2010
Posted by DWood538 on Sunday, April 6, 2014 9:12 PM
Thank you so much Fly-n-hi, that's some great information I'll probably try on my next model. It came out great on yours so hopefully I can have some luck with it (hopefully)
-Derek
    December 2006
Posted by Fly-n-hi on Sunday, April 6, 2014 9:18 PM
DWood538
No problem!  I would suggest practicing on an old model that you won't miss if you mess it up.  I practiced on one of my old Revell Superhornets and I was able to work on the technique before I risked it on my "good builds."  I also was able to try several different colors to see what worked and what didn't.
    December 2006
Posted by Fly-n-hi on Wednesday, April 9, 2014 3:10 PM
Alrighty, I'm getting close to the finish line now!  I've added one or two more filters since the last update and that's gonna be it.
I've attached the pylons, weapons and burner cans.  I've also attached the clear and red lights on the vertical stabs.
I'm really happy with the way the weathering turned out.
In the pic above you can see that I've attached the (fuel dump?) vents and the aft end of the CFTs.  They are painted bare metal as well so they are a little difficult to spot in the pic.
I only have a few little things left.  Should be done very soon!
    February 2014
Posted by T3chDad® on Wednesday, April 9, 2014 4:31 PM
Getting there.  I can't wait to see the final/completed project!
Dre
    June 2007
Posted by Dre on Wednesday, April 9, 2014 6:48 PM
Fly- you're going to have to wrap this up as I'm running out of superlatives to use here....Yes
    June 2013
Posted by bvallot on Wednesday, April 9, 2014 11:32 PM
Fantastic!! =D
On the bench:
    December 2006
Posted by Fly-n-hi on Thursday, April 10, 2014 12:20 AM
T3chDad®
I can see the light at the end of the tunnel!  I can't wait to see the completed project, too!Yes
Dre
Ha, thanks!  I'm thankful they have been positive superlatives! Sorry I've been dragging my feet a little bit.
bvallot
Fantastic!! =D
Thank you!  My next post should be the final product!  Wish me luck!
    December 2006
Posted by Fly-n-hi on Thursday, April 10, 2014 4:42 PM
Ok guys, I'm calling this one DONE!
First, let me give a sincere thank you to all the folks who posted compliments and words of encouragement.  I definitely got a boost from all the nice things that were said.  And I'm certainly going to make more of an effort to be encouraging of other's progress threads.
I'll just post a few pics here and I'll post a new completed build thread so that the final pics are right there at the beginning instead of on page 10.  And you'll have to forgive the quality and composition of my pictures.  I'm very novice with a camera.
And finally, here she is:
Look for more in my completed F-15E thread!
    September 2013
Posted by Dean30 on Thursday, April 10, 2014 4:51 PM
Masterpiece!
    November 2010
Posted by Eagle90 on Friday, April 11, 2014 5:39 AM
Absolutely AWESOME!  I'm getting flash backs from looking at her!  Great job and I look forward to your next WIP thread!  Thanks for sharing the experience with us!  Bow Down
Eagle90
    February 2014
Posted by T3chDad® on Friday, April 11, 2014 7:54 AM
Wow!  Definitely something to be proud of!
    December 2006
Posted by Fly-n-hi on Friday, April 11, 2014 10:30 AM
Dean, Eagle & T3ch, thank you!
Eagle, I've got a Revell 1/144 C-17 that is about 60% done.  I've been posting progress pics in the Mighty Mini's GB.  Unfortunately that GB is pretty much dead so maybe I'll start an independent thread.  I put that one on hold to finish the F-15E.
    March 2014
Posted by Tarasdad on Saturday, April 12, 2014 11:09 PM
I just started on this same kit tonight thanks to this thread! I've had the kit for quite a while, just never had the courage to get started on it. One thing I will say is my eyes and hands just aren't up to the level of detail painting I used to be able to do. Guess there's quite a difference between 22 and 52!
Tarasdad
On the Bench:
  • Revell 1/48 F-15 Strike Eagle
  • Revell 1/48 A-10 Warthog
  • Revell 1/426 USS Arizona
    April 2011
Posted by Ghostrider17 on Saturday, June 28, 2014 2:40 PM
where did you get the bombs from? Was it one of the hasegawa weapons sets?
    December 2006
Posted by Fly-n-hi on Saturday, June 28, 2014 3:08 PM
Tarasdad
Tarasdad, I just now saw this reply (June 28th). Thanks! I'm glad that you got something out of this WIP and I'm looking forward to seeing your Mudhen!
Ghostrider17
Ghostrider17, Yes, the GBU-12s, GBU-16s and the GBU-31 were from the Hasegawa Weapons Set D.
    April 2014
Posted by r13b20 on Saturday, June 28, 2014 4:31 PM
Absolutely fantastic! I love the way the bare metal areas came out. Masterful! The only thing I'm iffy about is the "dirt" and that's just an opinion thing, or preference. Perhaps one day I might be this good, but probably not. :) Great work. Bob
    December 2006
Posted by Fly-n-hi on Saturday, June 28, 2014 5:15 PM
r13b20
Thanks alot, r13b20!  Its ok to be "iffy" on the weathering.  I am the first to acknowledge that this is a fairly inaccurate weathering job.  But I do think its very realistic...sort of a "what if" weathering job...which is really what I'm trying to achieve.
I'm sure your builds are very good, too.  And I'm sure you'll be getting better as you go.
    April 2014
Posted by B_one fixer on Monday, June 30, 2014 9:22 PM
That is a outstanding Eagle!, I am waiting to build the same kit along with a monogram C model for an upcoming group build. I hope mine comes out looking this good also. I think what will consume most of my time is rescribing the C model monogram kit.
    December 2006
Posted by Fly-n-hi on Monday, June 30, 2014 11:44 PM
B_one fixer
Thanks, B_one!  I have a Hasegawa -C in the stash that I'm looking forward to starting, although it might be a while.  I bought a whole bunch of AM goodies for it, too!
What GB are you building yours for?
    April 2014
Posted by B_one fixer on Tuesday, July 1, 2014 7:29 PM
Hi Eagle,
I am building the pair of eagles for the Monogram Mafia GB starting on the 4th of July. I can't wait, The E model kit is begging to get started.
    February 2012
Posted by lawdog114 on Tuesday, July 1, 2014 7:39 PM
Impressive.  Those engine look real...thanks for sharing
Joe
