1:28 Revell Fokker Dr1 Complete
    July 2014
Posted by modelcrazy on Monday, September 7, 2015 11:29 PM
I have been looking forward to this kit in my stach for a while. Anyway I’m starting Manfred’s Fokker Dr1 Tri. This is an old mold with some flashing. I will be painting it in his famous red rather the pre-red 3 tone green of Jasta 11.
Steve
Steve
    November 2008
Posted by plasticjunkie on Tuesday, September 8, 2015 7:22 AM
MC
That is a rebox of the old mold going back to 1960 or so and it's actually a pretty decent kit with the help of some scratch work and pe. I got mine a while back at a garage sale for a buck or so if I correctly recall. It had a decal set from an IPMS convention issue from the 60's or 70's and they were still good.
I completely scratched out the pit and added pe details from Tom's Modelworks. FSM purchased the article but it hasn't been published and have no clue when it will be. It was partially built so I could not get into some areas to improve the detail cause I was afraid of damaging the fragile plastic.
Here are a couple of pictures of mine. As you can see, Tom's pe really dresses up the twin Spandaus over the stock ones.
 GIFMaker.org_jy_Ayj_O
    March 2015
Posted by Toshi on Tuesday, September 8, 2015 7:37 AM
I will be following your thread religiously during your build.  I'm looking forward to this one!  Also, nice build PlasticJunkie.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    November 2008
Posted by plasticjunkie on Tuesday, September 8, 2015 7:48 AM
Thanks Toshi.
Steve
Forgot to mention about the different shaped ailerons. I don't know how deep you are going with the build but here is a quote from one of Stephen Lawson's posts explaining the odd shaped ailerons and serial number range.
"Only approximately 15-18 of the initial production batch had the odd aileron set up.  This included Dr.I 135/17 -144/17 for sure.  After the Idflieg order to have them enlarged (among other things including factory spec top wings) the first machines to be refitted went through the assembly line with one of the older type ailerons still in use.   See Alex Imrie's book "The Fokker Triplane."
Now why would Revell match this?  The schematic for this and the old 1/72 scale kit were drawn up by Revell of Great Britain in the early 1950's.  The plans they used were from "Flight" magazine  and were of a machine that had been brought down on Jan. 13, 1918.  Fokker Dr.I 144/17  was one of the odd aileron machines.  It was studied and then had half of its fabric covering removed and was displayed along with other captured German machines in Ilsington at the Agricultural Hall for the benefit of the RAF hospital.  A penny would get you a walk through in 1918."
Posted by Don Stauffer on Tuesday, September 8, 2015 8:40 AM
More proof that not all really old kits were junk.  Very nice!
    April 2010
Posted by Theuns on Tuesday, September 8, 2015 9:10 AM
I have been looking at this kit for some time, will be watcing :-) As a matter of interest, do you know what the reason is for the "cutouts" in the mid wing at the wingroot? So that the pilot could actually see where he was going when on the ground :-) Theuns
    November 2008
Posted by plasticjunkie on Tuesday, September 8, 2015 9:43 AM
Theuns
That sounds like a very good reason to increase pilot visibilty.
Thanks Don. I also have the old Camel and it too makes an impressive model , again with scratchwork and pe updates.
    August 2015
Posted by crown r n7 on Tuesday, September 8, 2015 9:47 AM
Werner Voss nice build. I made this kit so many times in the 60's
 Nick.
    July 2014
Posted by modelcrazy on Tuesday, September 8, 2015 9:49 AM
This is such a cool plane, looks kinda unstable though. I understand that while not as fast as most of the allied fighters (too much drag) it could really turn on a dime (a lot of lift). PJ, you are so good at wood recreation, I should send you my prop to paint Wink. Just kidding, I need to learn myself. That paint job looks very convincing. Looks like it was painted with a dope wash of varying shades of green. I'll look into a PE set, maybe I can find one on the cheap on eB. Thank you everyone for your interest.
PS.
Thanks Theuns for that info. I kina wondered what that was for.
Steve
    April 2010
Posted by Theuns on Tuesday, September 8, 2015 10:57 AM
The reason for the 3 wings was to increace wing area therby making for a lower wingloading, this equals a much better climb rate. You do not want to simply increace wingspan as this reduces roll rate. Because of the rotary engine's massive gyroscopic effect it wouls not react like a normal plane, if you could master it , it was extremely agile. Just like Sopwith Camel, you used the same direction of rudder offset to turn left and right! These rotaries also dod not have a norma throttle, you had selector switches that turned off some of the spark plus thereby decreacing power. That is why they "blipped" the engine for landing. Theuns
    July 2014
Posted by modelcrazy on Tuesday, September 8, 2015 11:24 AM
I just ordered the cockpit and gun detail set from Tom's Model Works. It should be here soon.
Steve
    November 2008
Posted by plasticjunkie on Tuesday, September 8, 2015 1:18 PM
Thanks Crown but actually it was not Voss's machine. This machine is Dr-1 183/17 Flown by Hasso von Wedel of Jasta 14.  Easily confused with Voss's mount from the top picture I posted.
The streaked scheme is olive green streaked over unbleached linnen at different angles per documentation.
    August 2015
Posted by crown r n7 on Tuesday, September 8, 2015 1:42 PM
still looks great
 Nick.
    November 2008
Posted by plasticjunkie on Tuesday, September 8, 2015 1:44 PM
Steve
Not a problem if you want the prop done. I can PM you my mailing address. I will be more than glad to grain the prop for you.
    July 2014
Posted by modelcrazy on Tuesday, September 8, 2015 1:57 PM
plasticjunkie
Hmmm Hmm That is tempting. There's no way I could do as good a job. I'll give it a try on a scrap piece and if I just can't get it, Ill PM ya. I studied your discription on your guillotine last year and have tried it a few times with terrable results. Confused
Steve
    November 2008
Posted by plasticjunkie on Tuesday, September 8, 2015 2:10 PM
Thanks again Crown.
Steve
Not a problem. Shoot me a pm if things don't work out.
    June 2014
Posted by BrandonK on Tuesday, September 8, 2015 8:07 PM
I was eyeballing this kit yesterday on the web. I'm keen to see how this turns out.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
Posted by Don Stauffer on Wednesday, September 9, 2015 9:11 AM
Theuns
It is sometimes said that these engines did not have a throttle at all- they did, it was just that carburetor design was primitive, and the throttle was only useful for gross changes in power. This was true of all engines of that era, not just rotaries.
In early automobiles the same problem existed.  The throttle was just for going between idle and drive, for example, with fine speed control done by changing spark advance.  It took a few decades for carburetors for cars to develop adequate throttle response.  Such response was less important for aircraft, so aircraft engines had poor throttle response for half a century!
GAF
    June 2012
Posted by GAF on Wednesday, September 9, 2015 10:05 AM
Nice!  Look forward to seeing this one built.
Plasticjunkie>  And I look forward to seeing the article someday!
Meanwhile, you can never have too many Dr.1s.  Cool
However, I question the accuracy of some of the build details!  Surprise
But they fly well...
    July 2014
Posted by modelcrazy on Wednesday, September 9, 2015 4:04 PM
Great pic GAF, where was that at? I see a D5 slipped in there.
We have one at the local museum. I may have to go and get some more pics.
Steve
GAF
    June 2012
Posted by GAF on Wednesday, September 9, 2015 5:45 PM
modelcrazy> That was at Aerodrome '92 held at Lake Guntersville, Alabama. Frank Ryder had a WWI museum there in the early 90s.  It's gone now.  This thread over at the aerodrome will explain a bit better.
http://www.theaerodrome.com/forum/showthread.php?t=20836
Yes, go and take pictures.  You never can tell when this aircraft will disappear.  Tongue Tied
And while looking for information, I ran across this video from 1992 of the show!If you've got time (it's over an hour long) you might find it interesting.  I'm going to have to peruse it carefully as my friends and I are probably in it somewhere!  Cool
https://www.youtube.com/watch?v=LUycx74EVww
    July 2014
Posted by modelcrazy on Thursday, September 17, 2015 10:33 AM
PJ,
I tried my hand at the prop, however it didn't dry and the oil paint is showing cracks. I started with a base of MM wood enamel, then a coat of thinned Brunt Siena followed (a few days) with an application of Burnt Umber (I may have those reversed). Last night, after a few days, the prop was still sticky and the oil paint was cracked. I removed the paint and started over. If I can't get this right, I may just send it to you after all. What am I doing wrong? I started to take a picture but changed my mind.
Steve
    November 2008
Posted by plasticjunkie on Thursday, September 17, 2015 2:11 PM
MC
This is how I did mine:
Painted with MM acrylic wood color
Laminations painted with craft acrylic burnt umber paint
A day or two later began brushing washes of artist oil burnt umber as filters and using a hair dryer to speed up drying in between wash coats. I did about 3-4 light wash filter coats a day until I liked the effect.
Prop was set aside to cure for a few days then given a brush coat of Future for the varnished effect followed by the Axial logo decals.
Carefully use some thinner and a soft brush to remove all the oil paint and start again as I described.
    June 2014
Posted by BrandonK on Thursday, September 17, 2015 2:17 PM
The bird Steve is referring to is a replica and it is one of those displays that may indeed not be there one day, because they do rotate the displays from time to time. I have no idea how long it will be there, so get over there Steve.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    July 2014
Posted by modelcrazy on Thursday, September 17, 2015 2:32 PM
Thanks PJ,
I'll start over with acrylics and follow your method.
Brandon,
Yeah, I need to get back over there and get some more pics of it.
Steve
    November 2008
Posted by plasticjunkie on Sunday, September 20, 2015 5:17 PM
Brandon
Just wondering how's the prop wood graining coming along?
    July 2014
Posted by modelcrazy on Sunday, September 20, 2015 6:29 PM
plasticjunkie
I went OK I guess, not supper blown out of my seat amazed by it, but I will do. I was planning on working a little on the cockpit tonight, now that I received Tom's PE set.
Steve
    November 2008
Posted by plasticjunkie on Sunday, September 20, 2015 7:16 PM
Brandon
The graining looks very good. I don't know why you are kicking  yourself. How many oil washes did you do?
    June 2003
Posted by allan on Monday, September 21, 2015 1:25 AM
1/28?  Odd, I suppose its box scale?  Anyway, looking forward to this build, Steve.  Great work on the props!
PJ,
Thats a fine Fokker you did! Hard to believe its a 60s era kit.
No bucks, no Buck Rogers
    March 2015
Posted by Toshi on Monday, September 21, 2015 5:15 AM
Wow.  I love the authentic props!
Toshi
