Eduard 1/32 tamiya phantom cockpit pe help
    January 2015
Posted by TheMongoose on Saturday, March 4, 2017 4:29 PM
can anyone help me with what part 22 is supposed to look like when assembled? I understand the small piece of plastic rod. Piece 22 is straight on the PE sprue but the picture appears to show something concave. I can't be looing at this correctly. Thought someone may have a picture of finished work I could check out or an explanation of how I assemble this part?
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
    July 2008
Posted by jeffpez on Sunday, March 5, 2017 5:10 AM
The illustration for part 22 shows it with the 1mm dowel already attached. That in turn goes on part 23. Part 22 is flat. Eduard's instructions could be vastly improved by adding a photo or two of completed assemblies or at least a better drawing.
    August 2005
Posted by Phil_H on Sunday, March 5, 2017 5:42 AM
I believe this part represents the rudder pedal adjustment crank. The diagram showing part 22 as round is actually incorrect. It's elongated, with the plastic rod forming a knob on one end (think of a manual car window crank) and the other end attached to the centre of part 23.
Check the photo here: http://aviation.watergeek.eu/images/f-4cde/f-4e_rear_maverick.jpg
EDIT: Looking again at the diagram, it makes a little more sense. At first it looks like a representation of the part with the plastic rod attached. It isn't. It's actually a flat keyhole shaped piece where the plastic rod attaches to the "long" end of the keyhole.
    January 2015
Posted by TheMongoose on Sunday, March 5, 2017 10:42 AM
BeerAhhhh! Perfect, now i see what it is. Window crank really helped the visual. Off to finish this up now Beer
Posted by Melgyver on Sunday, March 5, 2017 11:01 AM
A one aspect drawing can have more than one interpretation.  I took a mechanical drawing class and the instructor told us one of the objects we had to make a 3 plan view of could be drawn a second way.  Usually only one or two people in the class sees the "other" way.  I was the one that saw it different!
Clear Left!
Mel
    May 2013
Posted by Greg on Sunday, March 5, 2017 11:32 AM
This thead is a great example of why I love this place and the folks.
Being fairly familiar with Eduard PE instructions and wanting to help, I studied the pic for a long time and couldn't figure it out.
What a great and concise answer, Phil.
Oh, and I studied what was then called drafting and design in college and still interpreted the drawing wrong, just as Mel mentioned above.
    January 2015
Posted by TheMongoose on Monday, March 6, 2017 6:27 PM
Mel I was one of the "other" kids in the class. Glad you could figure it out as I was lost. Between your explanation and the picture from Phil it made complete sense. Now I need to make some stretched sprue for the 1mm rod and I will be set. Here's my progress so far.
