Academy 1/72nd P-47D Completed Page 2
    June 2014
Posted by BrandonK on Saturday, June 17, 2017 11:31 AM
OK, so I've looked the photo over very closely and I can say with 100% certainty that those ARE invasion stripes under the stars and bars. 3 white and 2 black with perfect spacing, it can be nothing else. Those are NOT painted over and the photo must have been taking very very close to either side of the invasion, likely after. It's your kit, but if it were mine, I would most certainly add the stripes. That's just my opinion, but they are there.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
Posted by Bish on Saturday, June 17, 2017 12:01 PM
Thanks for the input BK. What i don't get is why they look so ragged and why the white does not show on the undercarrage doors. It would take some time for that to achieve such a worn look.
    June 2014
Posted by BrandonK on Saturday, June 17, 2017 1:33 PM
That occured to me as well. I'm thinking you are looking at a plane that has or is undergoing the coverup of the stripes and is either sloppy or incomplete. Tough to paint that look though. I'd be lazy and either paint with or without stripes depending on what look you want.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
Posted by Bish on Saturday, June 17, 2017 1:57 PM
I am wondering if this might have been taken after the unit had switched to P-51's.
Well, i have decided to play safe and go without the stripes for a pre d-day finish. Safe and easier.
Thanks again for the input.
    November 2008
Posted by plasticjunkie on Saturday, June 17, 2017 7:49 PM
I remember seeing somewhere those invasion striped being painted using big brushes and even a mop. They did not look very neat either.
As for your plane, maybe the stripes were hastilly applied, not enough paint to go around, etc.
If the stripes are there under the wing, they may not have painted the doors due to the demarcation lines not matching? We can sit here and just imagine a bunch of scenarios.
 GIFMaker.org_jy_Ayj_O
Posted by Bish on Sunday, June 18, 2017 3:46 AM
Ye, thats true PJ. Didn't think about that under the wing. I know the orders were issued at short notice. It could have also been that if the unit was in transition, they may have just done a quick job knowing the aircraft would be replaced in a few days.
As you say, could be anything.
Posted by Bish on Tuesday, June 20, 2017 2:13 PM
Got quite a bit done to my build in the last week. So after finishing off the seams and other small bit, got it masked up ready for primer and paint.
After a coat of black primer, it was painted with my usally brand of Xtracolor, grey underside and OD on top. I got a bit carried away and started masking for the white tail stripes before takeing pics. Those nose was also masked for the green band.
For the white bands, i started out with a coat of Alclad clear gloss. I have had issues in the past with Alclad primer bubbling when applied on enamel paint, so better safe than sorry. This was followed with a coat of white primer and a coat of white Humbrol gloss enamel.
I made up my own mix for the green nose band.
Blurred pic alert, sorry about that.
Then my favorite bit, dcals. These are from LPS Hobby and were really nice to use. I didn't go to mad with the stencils.
And yes, i have just this moment spotted that i have missed a piece of the national insignia. Will fix that.
And i added the door for the ammo section of the gun bay before weathering.
I just have to finish off wiring the engine, then i can get that and the nose fitted and then start on the weathering.
So thats all for now.
    November 2008
Posted by plasticjunkie on Tuesday, June 20, 2017 10:17 PM
That's a fine looking paint and decal job Bish. You are almost done with this one.
Posted by Bish on Wednesday, June 21, 2017 12:49 AM
Thanks PJ, yep, almost there.
    January 2017
Posted by damouav on Wednesday, June 21, 2017 2:54 AM
Excellent work Bish!
Really like the Jug in Olive Drab, you have produced another supereb build. Not such a fan of decals as you are, need to do more research on producing my own me thinks.
Damian
P.S. Having a background in Graphic Design, Illustration and Drafting helps.
In Progress
1/48 Tamiya P47-D Bubbletop
1/48 Hobby Boss TBF-1C Avenger (on hold)
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
Posted by Bish on Wednesday, June 21, 2017 4:15 AM
Thanks Damian.
I like the decalling stage because it gives the subject an identity. It turns it from just a tank or planeto a certain one with a history and a crew.
I have made my own a couple oftimes where i could not buy ones i wanted and like most things it turned out easier than i expected and was pleased with the outcome. Its somthing i should do more of.
    June 2014
Posted by BrandonK on Thursday, June 22, 2017 9:29 AM
She's looking might fine. A jug in the making for sure.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    August 2013
Posted by Jay Jay on Thursday, June 22, 2017 9:34 AM
It amazes me how you lined up those tiny interior wing supports just perfectly. GEEEZ you're good!
    March 2015
Posted by Toshi on Thursday, June 22, 2017 9:41 AM
Awesome job, things are really pulling together just fine!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
Posted by Bish on Thursday, June 22, 2017 10:34 AM
Thanks guys.
Jay Jay, i think that was mostly down to the Aires set. As long as you cut the panels out right, it fits nicley. I will see how it all looks once i get the guns in a barrels on.
    August 2013
Posted by Jay Jay on Saturday, June 24, 2017 6:50 AM
Bish
Thanks guys.
 Ahh I see. I'm looking forward to the rest.
Posted by Bish on Monday, June 26, 2017 4:32 PM
Thanks Jay Jay, me to.
Posted by Bish on Sunday, July 2, 2017 6:30 AM
Time for me to wrap this up. Took me a couple of days to get back into it after the weekend away, but once i did i just got stuck in, but there wasn't ,much progress to show anyway.
After the decals, it was just a case of some flory washes. I also added some oil staining useing AK interactive engine oil behind the oil dump and very light exhaust staining inderneath at the rear. Trying to do the engine useing lawdogs tut in this scale was almost impossable. Some of the pieces just need to be so smal you just can't get hold of them. And once its fitted, you can't see anything anyway.
I used some Aluminium tubing for the gun tubes. They are not to bad, but a litle rough. Next time i'll stick to masters metal barrels.
So heres some pics.
And then to add it to the base for a simple little dio.
Thanks for looking and following along.
All comments welcome as always. Now onto some armour.
    September 2016
Posted by ManCityFan on Sunday, July 2, 2017 9:00 AM
Nicely done! The figures definitely add to the completed kit. Painting is superb. Now we get to watch you do some armor. Excellent! D
Dwayne or Dman or just D.  All comments are welcome on my builds.
    January 2017
Posted by damouav on Sunday, July 2, 2017 9:14 AM
Brilliant exacution Bish, just Brilliant.
I really like the diorama, the paint on the Jug and overall exacution.
Top points.
In Progress
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
    April 2016
Posted by Hodakamax on Sunday, July 2, 2017 10:53 AM
Bish, Excellent job! That 1/72 stuff is getting too teeny for Max! What's next?  Big Smile
Max
    August 2013
Posted by Jay Jay on Sunday, July 2, 2017 11:20 AM
Oh Man, that came out a beauty. Lovely paint job and details as well. but one critique if I may..it's just too small  LOL
Posted by Bish on Sunday, July 2, 2017 11:24 AM
Thanks for looking in and the coments guys, its much apprecuiated.
Max, Jay Jay, you know what they say about good things coming in small packages. Wink
But as i always say, its what i am used to. Been doing 72nd for a long time and it suits me especially for diorama's.
And next up is a 35th Pz II.
    June 2014
Posted by BrandonK on Sunday, July 2, 2017 11:53 AM
Spectacular Razorback. That turned out very beautiful, Bish. Another well done kit. Love it!!
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    November 2008
Posted by plasticjunkie on Sunday, July 2, 2017 12:10 PM
Super job as usual Bish. The figures gives it a sense of scale.
Posted by Bish on Sunday, July 2, 2017 1:12 PM
Thanks guys. This is certainly bigger than my usual single seat fighters. It seems to just exud how powerful it is.
    January 2015
Posted by M. Brindos on Monday, July 3, 2017 11:58 PM
Wow! Once again you did a superb job, Bish. Your figure work is excellent as well! Those "JUGS" were enormous fighters alright. Big and powerful!
Lots to love about this one!! :)
- Mike Brindos "Lost Boy"
Posted by Bish on Tuesday, July 4, 2017 1:54 AM
Thanks a lot Mike. And i was checking out your fig tutorial and used that to imprive them from what i had done before. So thanks for that as well.
    January 2015
Posted by M. Brindos on Tuesday, July 4, 2017 3:31 PM
I am so happy that my simple tutorial helped you so much. Those little guys look quite convincing! That makes my day!! :D
Posted by Bish on Tuesday, July 4, 2017 3:38 PM
Thats what this place is all about Mike. Shareing what we know with everyone else. Till now i have just done a quick paint job on my 72nd figures, concentrating on improving my main subject. But know i am at a level i am happy with, it time to work on the smaller things.
