1/32 Tamiya Mosquito FB Mk. VI, 235 Sqdn, Overlord (Complete)
    July 2019
Posted by Hoss WA on Saturday, November 28, 2020 2:38 PM
DRUMS01
Excellent! At this rate, it will be a stunner when completed. I believe we are all looking forward to the next update.
PS: Good skills/ technique
Ben
Thanks Ben!
    July 2019
crown r n7
Looking real nice
Thanks Nick
    July 2019
Posted by Hoss WA on Saturday, November 28, 2020 2:53 PM
Buckeye2
That looks amazing!  Very well done!
Was curious what the painted yellow circles on the bulkheads are for?
Thanks Mike! Much appreciated. I'm not 100% sure about the yellow circles on the bulkheads, but I saw a credible explanation somewhere that they indicate magnetic steel armor plate, which could impact compass readings. No idea if it's accurate.
    July 2019
Posted by Hoss WA on Saturday, November 28, 2020 2:54 PM
1943Mike
This IP build is the cat's meow!
Super nice detailing!!
Thanks Mike!
    July 2019
Posted by Hoss WA on Friday, December 4, 2020 6:17 PM
The Merlin engines are now complete. I painted the left one since it will be displayed and will button up the right one. Tamiya and MRP paints were used as well as a Flory wash and Testors flat lacquer. It's all OOB except the ignition wiring. Tamiya did a great job with the detail on these. The wings are next.
Here are the engine photos. I used a good color reference photo for the exhaust. I'll do some more weathering when it's integrated into to the rest of wing/nacelle.
The wheel wells are integrated into each nacelle behind the engine.
The wings are next.
    November 2020
Posted by Xraylizard on Friday, December 4, 2020 8:14 PM
Fantastic craftsmanship !
    January 2020
Posted by wpwar11 on Friday, December 4, 2020 9:20 PM
Your killing it.  This is great work for sure.
    April 2012
Posted by nearsightedjohn on Saturday, December 5, 2020 9:49 AM
Really like the look of those exhaust manifolds - what paint(s) did you use to create that look of a slight start of corrosion? I've had some luck airbrushing a light spray of Tamiya Red-Brown XF-64 over flat black.
Thanks for sharing your excellent build in progress, looking forward to seeing this big boy come together!
Posted by jeaton01 on Saturday, December 5, 2020 8:02 PM
Sweet!
John
    April 2015
Posted by Mopar Madness on Sunday, December 6, 2020 9:22 AM
Those Merlins are so detailed!  Excellent finish.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    August 2015
Posted by crown r n7 on Sunday, December 6, 2020 9:32 AM
Mighty fine engines Toast
 Nick.
    July 2019
Posted by Hoss WA on Monday, December 7, 2020 8:38 PM
Xraylizard
Thanks Xray!
    July 2019
Posted by Hoss WA on Monday, December 7, 2020 8:39 PM
wpwar11
Thanks wpwar!
    July 2019
Posted by Hoss WA on Monday, December 7, 2020 8:50 PM
nearsightedjohn
Thanks John. Much appreciated. I used Mission Model paints this time but I think Tamiya would have been fine also.
I tried a different technique this time. I started with a gray primer, then painted the entire manifold dunkelgelb - a light tan. Then I mixed black, red brown, and "burnt metal" (a translucent gray-brown metallic) and applied the mix, avoiding the tips and feathering it across the manifold. I then applied each individual color in random spots and patches to create variation. I applied a light gray very thinly to the exhaust tips, except the front ones, to reflect the flow of exhaust gases over the manifold. Finally, I painted some random sharper lines with a very thin black-brown mix.
    February 2012
Posted by lawdog114 on Tuesday, December 8, 2020 9:22 PM
Your attention to detail is quite impressive.  That cockpit is one ofthe best I've ever seen.  I look forward to the rest.
    January 2015
Posted by TheMongoose on Tuesday, December 8, 2020 10:50 PM
Ohh just awesome. The detail you described on the exhaust really comes across superb. Worth every hour you invested.
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
    July 2019
Posted by Hoss WA on Thursday, December 10, 2020 3:13 PM
lawdog114
Thanks Lawdog. Much appreciated.
    July 2019
Posted by Hoss WA on Thursday, December 10, 2020 3:14 PM
TheMongoose
Thanks Mongoose.
    July 2019
Posted by Hoss WA on Monday, December 14, 2020 10:13 AM
The wings, fuel tanks and landing gear are now complete. No issues at all during these steps as the fit is perfect and the engineering is superb. I'm really starting to wonder where I'm going to display this beast...
The wings are actually mated to the main spar section with eight screws.
The gear on the "shelf" behind the pilot and navigator seats is nicely detailed.
Here's the engine that will be displayed with covers removed.
The PE radiator and frame detail is superb.
Nice detail on the fuel tanks, which will be tough to see once the cannons and bombs are added.
Jigs hold the landing gear together. I'll hold off on installing until after main painting is complete.
Integrating the wings and fuselage is next, followed by the cannons and bombs.
    October 2019
Posted by Tanker-Builder on Monday, December 14, 2020 10:21 AM
OHMIGAWD!!
 That is so perfect! Love the detail,but where would I put it? Oh Man,You are good. Luv Your work!
    November 2020
Posted by Also known as Rob on Monday, December 14, 2020 10:35 AM
That's looking really good.
Posted by jeaton01 on Monday, December 14, 2020 12:33 PM
It's going to be a shame to put the Merlin oil stains on that fine work!
John
    July 2019
Posted by Hoss WA on Tuesday, December 15, 2020 8:35 PM
Tanker-Builder
OHMIGAWD!!
Thanks Tanker-Builder!
    July 2019
Posted by Hoss WA on Tuesday, December 15, 2020 8:36 PM
Also known as Rob
Thanks Rob.
    July 2019
Posted by Hoss WA on Tuesday, December 15, 2020 8:38 PM
jeaton01
So true! Thanks.
    July 2019
Posted by Hoss WA on Sunday, December 20, 2020 4:05 PM
The 20mm Hispano cannons and the bomb handling racks are now complete. Tamiya did a nice bit of engineering on the cannon unit. All OOB for this step with no issues. The fixtures on the cannon barrels are alignment jigs to hold position while the glue dries.
Here's the cannon and bomb bay with the goodies installed. I've opted to not mount the bombs since they would obscure the nice detail.
Most of the heavy lifting is now complete. Next is getting the big beast ready for main painting.
    November 2020
Posted by Xraylizard on Sunday, December 20, 2020 5:32 PM
Could not have learned more about this plane if I saw it in real life !!
    April 2015
Posted by Mopar Madness on Sunday, December 20, 2020 5:38 PM
Man Hoss, that is just too awesome!
Chad
On deck: Who knows!
    July 2019
Posted by Hoss WA on Wednesday, December 23, 2020 9:42 AM
Xraylizard
Thanks Xray. In fact it's my first Mosquito build so it's a learning experience for me too.
    July 2019
Posted by Hoss WA on Wednesday, December 23, 2020 9:43 AM
Mopar Madness
Thanks Mopar!
