Nice build, it looks like you had some trouble with the decals, other than the silvering on the stencils, it looks like you lost the a piece of the national insignia on the left wing underneath on the aileron and also on the port side in the duct intake. This is always a challenge area on the jug, trying to apply those sections around the duct opening.
On a flat painted surface, it is probably easier to coat the stencil with future before you apply it, that always works for me. Cutting into the applied decal is risky and ...you have a slice in your decal, which ain't good either. Just for the heck of it, take a stencil, on some practice surface, lift it from the decal sheet using water, and either dip it, or brush a coat of future along the underside with a brush and apply it to the practice surface. You will be suprised at the result. Once the future is cured, then you can dullcoat over it and it will really look good.
A good build all around. Thanks for sharing...Steve
