compressor
    January 2005
compressor
Posted by longsnapper75 on Thursday, November 2, 2006 6:30 PM
i posted this over in the airbrush forum but i havent gotten a response. what is a good compressor to get for an airbrush? i dont want to spend a lot of money but i want something good.
    January 2003
Posted by leemitcheltree on Thursday, November 2, 2006 7:41 PM
I don't know if this is helpful, but I purchased a small garage type compressor for my model room.  It fits under the desk and is a piston type, which pumps into a holding tank (or pressure vessel).
The regulator draws off the holding tank (holds about 10 gallons, I think) so there's no "pulsing" feed to the airbrush.
I can spray for about 5 minutes continuously before I have to fill the tank again.
I got the thing from a place called Bunnings (in Australia)....a great big hardware warehouse (anything like Home Depot?)....it was only about $100....and even if it dies next month (I've had it more than a year) it's still been very good value.
I could have spent $600 on a dual pump, silent unit specially designed for model use - but I didn't see any point.
This one is pretty loud - so I just switch it on, leave the room and close the door.  It only takes a couple of minutes to fill the tank, and I've got a silent, continuous air supply.
Cheers, LeeTree
Remember, Safety Fast!!!
    December 2005
Posted by davew6003 on Thursday, November 2, 2006 7:44 PM
Well if you dont mind getting a larger and less quiet one, do what I did. Go to your local hardware store, Walmart or Sears etc... And buy a small compessor. They sell them to run small nail guns or to air up tires. I paid $70 dollars for one and it works fine, although it is loud. Make sure it has a pressure regulator so you can adjust the air pressure. They are a little bigger than an airbrush compressor about the size of a 20 inch TV or a little bigger. Hope this helps.
    December 2005
Posted by davew6003 on Thursday, November 2, 2006 7:46 PM
Well Leemitcheltree beat me to it. LOL Anyway this sounds just like what I have.
    June 2005
Posted by smokinguns3 on Thursday, November 2, 2006 8:22 PM
Ive got one thats about 4 gallons i picked it up at pep boys for 45 or 65 bucks  i cant remember its made by coalman.
Rob I think i can I think i can
Posted by rangerj on Thursday, November 2, 2006 9:08 PM
Here is an alternative to think about.
For about $150.00 U.S. you can get a 20 pound CO2 bottle, pressure regulator, and water filter (trap), plus the necessary fittings for attaching your airbrush. The CO2 is inert and non toxic. This set up is perfectly quit, easily portable, and inexpensive to operate. I get my bottle refilled about once a year at a cost of about $20. The spray pressure is consistent, that is there is no spitting from the pulse you get with most of the hobby airbrush compressors, and there are no moving parts to wear out. Understand that you are renting the bottle and when you go for a refill you simply exchange your current bottle for a refilled one. If you rent your bottle from a local Gas Supplier then you generally must get your refill from the same supply company. A 20 pound bottle is about 8 inches in diameter and stands about 30 inches tall. The bottle can be steel or aluminum. I prefer the aluminum tanks because they are a little lighter and do not leave a rust stain on the floor or carpet.
I have had a series of the 1/10 HP hobby compressors and they usually last about a year before the bearing siezes or the diaphram develops a pin hole or a crack. They also spit because they are a "pulse" type compressor. The larger compressors are generally noisy and use a lot of electricity. I have a 10 HP compressor with a 60 gallon tank in the garage. I thought about running a 1/4 inch line into the basement for my hobby use, but the compressor is noisy when it refills the tank, and with a 220 volt line it uses a lot of electricity ($$$). I work on my kits late at nght, especially on weekends, so the compressor noise is a deciding factor for me.  All of the suggestion above are good ones, but I thought you might like another alternative.
    January 2005
Posted by longsnapper75 on Friday, November 3, 2006 1:36 AM
ok cool. thanks for the help. i was thinking about trying an auto parts store and havent had time to get over there. now i know its a good place to go. thanks again. hopefully now i can get some models done and put some pics up.
    April 2004
Posted by Jon_a_its on Friday, November 3, 2006 4:16 AM
Save your ears, your neighbours goodwill & partner earache,
with resultant dog-house billeting..
Get a silent compressor, one with a tank is preferable. I'm now on my second one, a totaly silent, 'fridge based motor jobby, which also saves grinding of teeth, & now with my (old) Badger 150 & new Valleyo Air paint, i/m building less to practice with my a/b!
A company in the uk called Machine Mart have Clarke Schhh range, have a look & this will give you an idea or two
Clarke Wiz, as below, 'Quite' quiet, cheap, but pulses!
You should find US equivelents to the above.
http://www.airheadairbrush.com/  may give you clues to look for
failing that, there is always £b@y!
Jon UK
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    June 2006
Posted by Air Master Modeler on Friday, November 3, 2006 4:31 AM
Wal Mart carries a few good compressors and a few that come with tanks. The Cambell Hausfield compressor is pretty good... comes with air regulator adjuster, PSI guage and just about any air brush will work with it. The Cambell Hausfield starts at $50.00 and the downside of this compressor is it is loud.
Air Master
Rand
30 years experience building plastic models.
WIP: Revell F-14B Tomcat, backdating to F-14A VF-32 1989 Gulf Of Sidra MiG-23 Killer "Gypsy 207".
