My first everything - Spitfire
Posted by Anonymous on Tuesday, September 11, 2007 2:47 PM
1st Attempt at
Airbrushing
Multiple Colors
filling putty(horrible done)
decals
a plane
It not cleared or dull coated...just stickers on paint on paint. It was mainly justa  learning experience for me which I know ALOT more now and my next  models will be much nicer
    April 2005
Posted by wing_nut on Tuesday, September 11, 2007 2:58 PM
No doubt there are some things that can be seen but overall a good showing for all those firsts. And you have identified the areas yourslef so you know what to work on andthat is the best way toget better.  So keep at it.  1st one if the hardest.
shhhh.... nobodytell him it gets harder Whistling [:-^]         Wink [;)]
Marc
Posted by Anonymous on Tuesday, September 11, 2007 4:15 PM
Could have sealed paint, decals, dulled
The filling in the wings are much horrible....I didnt use masking tape
Model was not cleaned very well before hand
Canaopy had too much glue
canaopy not futured
Feal free to hit me with anymore
Posted by jeaton01 on Tuesday, September 11, 2007 4:53 PM
Not so bad, especially with all the first time aspects.  Onward and upward, practice, practice, practice!  First thing you know you will be displaying your work in Carnegie Hall.
John
    June 2007
Posted by ironokie on Tuesday, September 11, 2007 5:30 PM
Wasteland,
 I can identify with all those first as I currently have one plane, a P-38, under my belt.
 Did you mask to paint the camo or did you freehand?
 First plane huh? Nicely done.
                                            Kent
    March 2005
Posted by philo426 on Tuesday, September 11, 2007 5:40 PM
Pretty good first effort!The seam filling needs attention,especially on the lower wing/fuselage joint but the cammo looks good.I think with a little more practice you should be able to produce some very good models.
jwb
    February 2006
Posted by jwb on Tuesday, September 11, 2007 6:08 PM
First, I commend you on your choice of aircraft. Spitfires rule! Smile [:)]
Sure there are some things that you'll get better at, but don't be hard on yourself. It looks good! You've recognized areas to improve, you learned some new techniques, and you probably had a lot of fun! That's what it's really all about.
Keep building, keep having fun!
And remember- Spitfires rule! LOL
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
    September 2007
Posted by Jerm757 on Tuesday, September 11, 2007 6:16 PM
you should of seen my first! lets not go there!Big Smile [:D]
Posted by rjkplasticmod on Tuesday, September 11, 2007 6:23 PM
Not too bad for all your firsts.  Learn from the mistakes & you'll get better in no time.
Regards,  Rick
    June 2003
Posted by Lucien Harpress on Tuesday, September 11, 2007 7:10 PM
The two (self-admitted, I might add) things I would work on first?
-Decals (the whole clear gloss/decal/clear gloss/clear flat process- not that hard, just tedious.)
-Painted canopy frames.  A bit harder to do, but it's something to work toward.
On the other hand, you paint job is certainly commendable under ANY circumstances, first model or not.  From what I've seen this is the hardest thing that beginners have to get a hold of.  But you don't look to have any problem with it at all.
What does this mean?  Two or more projects (with some new small tweaks and new techniques each time) and I think you'll suprise yourself.
Is it a bit rough?  Yeah.  But it bodes well for the future.  REAL well.
I'm eager to see more.  Good job!
That which does not kill you makes you stranger...
-The Joker
Posted by Anonymous on Tuesday, September 11, 2007 9:20 PM
Waste Land. That looks as good as or better than my first. An easy way to dull the shine might be a flat coat over the decals. I'll give it a solid E for effort! Nice work!
Posted by Anonymous on Tuesday, September 11, 2007 9:30 PM
Thanks guys
 As for the painting process the first thing I did was mask off the sides and such and spray the bottom.....then took masking tape and just layed it across the bottom gentlyand let it hang.... so I got the edge between the  colors without a edgy line. Sprayed the earth brown, have it a few days to dry then took gobs of silly putty and smooshed them around to create my own camo then sprayed over it and removed within an hour.
I am REALLY looking forward to trying free hand camo, I just want to pick up some finer needles to try and also work on my Abing skills as well as my thinning skills.
BTW this was all done with acrylics
    December 2005
Posted by davew6003 on Tuesday, September 11, 2007 9:54 PM
I would have to agree fully with the Nut. Keep it up and you will be surprised how much better the next one will look.
Hey Florence, been there many times.Thumbs Up [tup]
Posted by Anonymous on Tuesday, September 11, 2007 9:57 PM
Where ya from?
    June 2003
Posted by Lucien Harpress on Wednesday, September 12, 2007 7:16 AM
...Which is pretty much the same way I do mine.  It's a pretty neat trick, eh?  Wink [;)]
-The Joker
    July 2004
Posted by mucker on Wednesday, September 12, 2007 10:05 AM
Great first build Waste Land! Now you've got the anxiety of the "firsts" over with, you'll be much more comfortable moving forward and improving your skills. I think MArc and some of the others said it best...it seems like you already know where you want to focus on improving, and that's the most important thing.
I'm looking forward to seeing what rolls off your assembly line in the future.
    February 2007
Posted by Luftwoller on Wednesday, September 12, 2007 12:56 PM
As has been said before, for a 1st AB job, you did great. Use the search facility on FSM and use the wealth of information on offer here to help you improve (I still do). Also some of the contributors on here (Wing nut, JWB, Swanny etc) have there own websites that have some invaluable tips that will be of great use to the new modeller (and Old).
So keep up the good work and dont be afraid to ask questions. Remember, No question is a silly question.
...Guy
..'Your an embarrassment to the human genus, makes me ashamed to call myself Homo'.
Posted by TANGO 1 on Wednesday, September 12, 2007 2:11 PM
There is an old saying.......if it looks right-it will fly right.
I think that applies here, you set out to builld a Spitfire and thats what you have done. Considering the ammount of firsts you had here I'd say you did a good job.Thumbs Up [tup] I am certainly impressed because that is waaaay better than my first Spitfire!Wink [;)]
Regards, Darren. C.A.G. FAA/USNFAW GB
Posted by Anonymous on Wednesday, September 12, 2007 6:09 PM
Thanks again for all the compliments and all the points in the right direction.
I'm currently working on a black 32' Ford Highboy. Which will be my first car done with airbrushing, decaling and future coating.
    December 2005
Posted by davew6003 on Wednesday, September 12, 2007 6:26 PM
Where ya from?
Was born in Birmingham but I live in Tuscaloosa now.
    January 2003
Posted by yardbird78 on Wednesday, September 12, 2007 7:36 PM
Pretty decent results for a first effort.  You have identified your areas that need work, so you are well on the way to better modeling.  Practice makes perfect, (or at least closer thereto).
Darwin, O.F.  Alien [alien]
The B-52 and me, we have grown old, gray and overweight together.
