Butz wrote: |
Just a quick question.... Not saying that you are wrong in what your saying but.... Just looking at the Block 60 looks to me more like a F-16D Blk 52J w/ Conformal Fuel Tanks. I know that the "Echo" & "Foxtrot" differ w/ an internal, FLIR navigation sensor that is housed on the front upper section of the a/c kind of like a "Ball Turret". That alone make it stand out from all the other variants. You also have externally; a targeting pod w/ a facetted windows.. And if you notice, the pitot tube has been omitted from this Block number. As you mentioned, it also has various other blisters n exhaust ports.. Anywho, I truly can not see why not eagle15 can't use the Isreali F-16 that comes w/ the avionics fairing and order the after market CFT's.. Ok w/ a little TLC and some scratch building of the various bumps and blisters as mentioned, he could get away with it.. As for the interior, I myself have not gotten close enough to one to say.. I am sure though that they added a few other CRT screens, switches and the like since this is the most advanced Falcon on the market. |
Block 50/52 front cockpit:
Block 60 front cockpit:
As you can see the MFDs are much larger in the Block 60 and thus required a resdesign of the front instro shroud. There are no current conversions for this, it would have to be scratchbuilt.
The IRST ball on the nose is called Falcon Eye:
It works much the same as the MiG-29 system, and is integrated into the JHMCS. Also, no current conversion, would need to be scratched.
The targeting pod you mention is the Sniper XR pod:
There are a couple of these in resin currently.
Every new closeup pic that I see of the E/F shows a new panel line, scoop, exhaust port, ane/of bump that isn't present on any other variant. The pitot tube is present, but not on the nose anymore. An additional alpha probe was added to the port side, pointing about 45 degrees down, and that serves as the pitot tube:
It's the second red pyramid cover that's protecting the new pitot. You can slo see in the above pic the revised radome panel line. It now open upward instead of sideways. You can also sev several bumps not present in other variants, and the new slime light strips.
Yes, the Sufa is a good place to start, but again, there's a lot more to get it to true E/F standard. Sure, you can get away with it to a point, with little effort, but in my opinion, it's just too different to get it close enough.
On the Bench:
1/48 F-16N: FINISHED!
1/48 F-16DG Aviano: FINISHED!!
Stealing joy since 1993.....
